Warp2003 said:
So Jm.... in your opinion....
What would it be the solution to this dilemma?? How Could you achieve it?? Is already available somewhere???
Cheers....
I am trying to come up with a solution as we speak
Anyhow, I never really rode the "propedal" fox shox, I kind of "bypassed" them (this will make sense later) but in my opinion, the "perfect solution" is a shock that has adjustable low speed compression damping, with a seemless blowoff, also one that can "keep up" at high speed just fine. This isn't super hard to do, but it isn't something we've seen much of untill fairly recently. Romic basically has an adjustable low-speed compression mechanism with a blowoff, avalanche has had adjustable low speed compression and I am sure it has a blowoff too. What does not have a blowoff is the countless fox RCs that are still around, the compression adjustment had no blowoff, and affected the entire range of compression, rendering it useless for any kind of compression adjustment. The 5th element and all CV/T shocks have an adjustable platform, with a blowoff. This is a little different, but I think the biggest folly is that you can not turn this feature "off" all the way, it still behaves the same when you run the minimal amount of pressure, it's just that it's to a lesser degree, but it is still very noticable to me. The holy grail is a platform that can be turned all the way "off", or the adjustable low speed compression that has the same kind of adjustability. This is starting to become more popular, and all the evidence right now points to the new fox DHX as being the perfect blend of adjustability (as in making it super-plush or "firm" for pedaling), which is why I ordered one this morning
We shall see. I have owned multiple CV/T shocks, they are ok, I think that the suspension action is lacking. I've owned many non-CV/T shocks, and I think that with the addition of adjustable low speed compression, these could be much more stellar than they are just by themselves. The new DHX is supposed to have completely "decoupled" propedal and progression adjustments, supposedly it's the only shock that has this, but I do know that the progression (air volume) and platform (pressure) adjustments in the 5th element are coupled, you get the biggest platform effect when running the air volume on the small size, and running the air pressure on the high side, at least this is what the progressive techs told me, and if what they told me was true, then it means that the CV/T technology is not "decoupled", for whatever it is worth. There's also better valve technology that can be (and is being) brought about, the Push dual stage piston damper is one example, and they are supposedly very impressed with the new fox DHX as well, which means that it most likely has a much better piston/damper than the old vanilla RC models.
Who knows where it will all go, but adjustable low-speed compression with a seemless blowoff would go a long ways for me, romic is almost there but the reliability of their design is just horrible. It's the only shock I've ever blown 3x, I'm not easy on shocks, and I've blown all but one brand (the one that i've only had for a month though
). There's also the question of adjustable progression, which if done right, doesn't seem like it will hurt anything and be quite beneficial to many bikes and others. It's been done already obviously, but again, I'm not completely happy with the 5th, I think things can be a good deal better.
