Hi guys, I'm riding the first generation of the Darkside, might have seen my pictures in the beginning of the thread. Due to various factors in my life, I only started riding it this year. I'm very much a beginner, I only do small drops and jumps, but even then I completely bottom out my dbair cs, no matter what I do with the settings, even with the compression dampening turned all the way up. If I put in more air, my sag isn't correct anymore. Any tips? Should I add an extra volume spacer or better to switch to coil? I weigh 90kg (198lbs) with gear on btw.
Also, I find that my nose dives a lot on jumps, could that be due to the low rebound dampening setting on the shock not being high enough? (haven't touched it yet)
