Ok yeah tell us moreThis bike is a ripper. View attachment 1382333
Nice dude! What size frame and what size dropper?This bike is a ripper. View attachment 1382333
Medium 170mm reverb axs. FYI the post can be slammed all the way down!!Nice dude! What size frame and what size dropper?
What type of trails and riding are you doing?Thanks! I have spent some time on a following v3, wreck v3 and a 21 stumpy s-works s4 and I will say that this bike is the "ultimate trailbike" not the stumpy. The stumpy felt really similar to the following but was a little more plush. The offering feels more plush than the stumpy but it's almost as poppy and efficient as the following v3. I also had an offering v1 and it did feel similar to the new one but I would say the v2 is better all around. At 5'10" I ride medium Evil's and the extra reach on the v2 was a huge plus for me. I tried out both a large and medium following v3 and found the large to be slightly bigger than what I wanted.
Any comparison between it and the Wrecker? Does the Wrecker play nice as a trail bike or did you ever feel over biked?What type of trails and riding are you doing?
Thanks, that's good to know, have you had any incidents with tire coming in contact with the battery on the reverb when dropped?Medium 170mm reverb axs. FYI the post can be slammed all the way down!!
I had an 11/6 on the wreck and had one setting with a pretty poppy trail tune and I thought it was pretty good. If this is your only bike and you don't have regular access to aggressive trails I wouldn't recommend it. I think you should find the perfect bike for your local trails and then find a bike that has 10mm additional travel.Any comparison between it and the Wrecker? Does the Wrecker play nice as a trail bike or did you ever feel over biked?
The best way I can describe the wrecker on your average trails is you spend the whole time trying to convince yourself that it's too much bike but in reality the bike does really well, better in areas you'd think it wouldn't.Any comparison between it and the Wrecker? Does the Wrecker play nice as a trail bike or did you ever feel over biked?
6.62 LBs for a large.Anybody know what a frame weighs with the air shock?
Sent from my iPhone using Tapatalk Pro
Thanks so the 6.62 lbs is with the shock?6.62 LBs for a large.
.97 LBS for the spec'd shock.
Haha, nah. There are very few sub 6 LB frames on the market. The new Stumpy is one of them.Thanks so the 6.62 lbs is with the shock?
Sounds like 7.59 lbs for frame and shockThanks so the 6.62 lbs is with the shock?
