1 - 6 of 6 Posts
Discussion Starter · #3 ·
Thanks for info. What can I do? is Shimano XTR M750 Bottom Bracket 116mm Octalink V1, sealed cartridge compatible with Ultegra compact Octalink crankset?
if so, is 116 mm would be good my set up (use to have triple crankset on taper square)?
Discussion Starter · #5 ·
double (compact) crankset. frame bb = 73 mm.
I want to combine BB XTR M750 with Ultegra double compact crankset on a mountain bike frame.
Use to have a triple + bb square taper on that bike.
You're gonna have to be the test dummy on that one.
I used to have a good handle on what worked with Octalink 15 years ago..especially on cross bikes.
Then V2 came out...which was really confusing...
Then out board systems happened and I moved on.
Good luck!
1 - 6 of 6 Posts
