1 - 20 of 26 Posts
Currently have a Fox 34 Factory with 2019 140mm air shaft and FIT4. It's the max length this fork can go. It's on an Evil Offering with X2 rear. Fork has been overhauled with fresh oil and is set up properly.
What objective improvements will I expect with either a 140mm Grip2 damper (recent aftermarket option) or going straight to a new longer travel Pike if the 140mm isn't ideal?
FWIW, I'm 165 pounds geared up, our local trails are mostly loose over hard, not a lot of super long rocky or rooty descents. Just fast, g-outs, braking bumps forever. I'm not a jumper, but I do ride aggressively yet smoothly, if that makes sense. This will be my fun cornering playful descender so climbing performance is moot.
I'm still dialing in the Offering, and enjoy fine tuning the X2, and hope the flip chip and 140 fork work "perfectly" because it'd save me the cost of new fork, but if the Grip2 or new 150mm RockShox option are objectively better to the point of "whoa, that FIT4 has no business being on the front of this bike" then I won't hesitate. But if it's minimal, and I'd see more improvement with tire choice/psi and dialing in the FIT4 + X2, then I'd pass.
Thanks in advance.
The switch to the Grip 2 on my bike(s) was noticeable and positive. One is a Santa Cruz Hightower (Gen 1) and the other a Pivot Shuttle eMTB. Both are also set up with Fox X2 rear shocks, so the Grip 2 is a perfect match. I ended up running both forks nearly wide open on compression and am super happy with the way they perform, and noticeably better (or more accurately, better balanced) than the FIT4 and Grip 1 dampers that were in there before.
Also, the swap is a SUPER easy DIY project. 10 minutes.
I just installed a 2021 GRIP2 damper in my 2020 34 Float fork. Haven't had a chance to ride it yet other than a quick shakedown in the driveway to make sure everything felt good after the install. When I hit the trails I can report back. This is on my Tallboy 4.
I may do this with my 2020 130MM factory 34-----do you need to put oil in the fork and if so what type and how much-----I think the damper is a bit over $300 is that correct
I just installed the luftkappe and have only ridden it once----went from 62 to 70 pounds but next time I think 68----fork felt better for sure---I am about 170 ready to ride
While the fox36 fit4 really sucks and is probably the harshest thing i ever tried, i felt really good on a fox34 fit4 and i wouldn't change that.
Is this possible? Other people felt this?
Fox says 5wt Teflon infused for the GRIP2 damper side - seems like 40cc from what I gathered, as the 2021 34 GRIP2 specs aren't showing yet in the Fox tech section of their website. In the air spring leg, I put 10cc of 20wt Gold.
https://www.ridefox.com/fox17/help.php?m=bike&id=1056
I've been thinking about doing this on my 160/36. I've heard that there are so many adjustments/settings that its a pain to set up. For those that have done it how a
was it to set up?
I didn’t dislike my 34 FIT4 but the little sharp edge hits were what felt harsh. And I had LSC pretty open. Otherwise was fairly plush. My hope and from what I’ve heard the GRIP2 with separate adjustable HSC will tame those sharp edge bumps like roots, rocks.
I have newish 2018 fit4 36 27.5 boost 170
It felt like trash compared to my old xfusion vengeance coil hlr, but I need a 27.5 fork that could fit decent sized tires instead of a 26 inch straight streerer that could fit tiny 27.5 tires. I got a new old stock fork for 450 though so I planned to upgrade to coil any way, but I didn't know I would need a new damper too, grr. I am 185 with gear and run it wide open, but it feels pretty dead
Thanks in advance.
Rather than just pasting...
https://forums.mtbr.com/shocks-susp...ance-verses-factory-1137775.html#post14769167
In real life the difference is minimal, but the placebo effect is powerful.
Fit4 is a very good damper. Reports of it being harsh are likely due to things other than the damper. Grip2 is also very good and has some durability enhancements, but not sufficiently better to justify the upgrade.
If your fork feels too harsh on square impacts, it's probably the air spring. Try a luftkappe or push low friction seals. Before spending money, you can also try tuning with volume spacers, or even just dialing down rebound and/or increasing/decreasing air pressure. A lot of people seem to attribute poor set up to the fork being bad. Not so, fox36 and fit4 is an excellent product.
Sent from my VS995 using Tapatalk
None. Really. How do you think it is possible to improve anything every single year? And how do you think it is possible that every single year the new technological breakthrough is ready pretty much in the same month? Discovery runs on a clock? Luck? or simply a recurrent scum betting that people are ready to buy upgrades for the sake of buying?
Change your seals and oil regularly ... that is what people do when they install an upgrade and that is why the fork feels better ...
This is quite true. Also they are comparing a brand new damper with fresh oil to one that likely hasn't been serviced in a long time. That alone could account for a big difference.
I hope this is correct, but I did go from an old fork to a new one so it certainly wasn't the seal thing people latter suggested. The damper feels way over damped to me. I will mess with it some more and see if I can make it better, but as it is wide open there is nothing to do but air spring and rebound. I am tempted to just get the coil and then worry about the damper so I can do one thing at a time, but I will see what happens. I hate to invest time in futzing with spacers in the air spring when I plan to use a coil anyway.
I swapped to a GRIP2 on my FIT4 that was pretty new (20ish rides, ~ 25 total hours on it of trail riding).
Maybe yours is over damped. I've had my fox 36 fit4 push tuned so the damper valving is customized to my weight, bike, and riding style. It's possible you could benefit from that. But that is a set up issue, not anything inherently wrong with the damper or fork.
Disagree when it comes to the fit4 in the fox 34. I am very experienced with suspension systems and setup and there is nothing I can do to improve the harshness of the fit4 (2020 f34 fit4 mind you) in my 34 factory fork.
The grip 2 in my fox 36 is fantastic. Even with a service interval that is a bit too long, it's still good. Not so with my 34. Before you chime in about lower leg service intervals etc... I am fanatical about them and do lower leg services once every 4-6 weeks.
Not to be argumentative, but you're comparing dampers in two different forks. There are likely be a lot of differences beyond just the damper.
1 - 20 of 26 Posts
