double lenses (clear) model
Is the way to replace double-layer lenses the same as single? (Mine's getting some scratches, so eventually I'll have to replace it.)
Also, is the double-lens model different from the single-lens model, in terms of the goggles "frame" spec? Meaning, do I assume that the width of the groove inside the frame to hold the lens is different for double (wider) vs single (narrower) models? (YES/NO?) If that's true, I wonder if it's not compatible to occasionally install a color lens (single layer only) in my double-lens model frame? (Would it be too loose-fitting, per the wider groove in frame?)
Thanks for the info in advance,
- PiroChu
I have the anti-fog double-layer lenses model (clear only) of this. (And, not planning on taking on/off nose guard.)KavuRider said:and changing lenses is a snap!
- PiroChu
