Yeah, that's definitely not good, need to get this sorted ASAP. Fro previous threads, I remember you're a big/heavier guy, so you're going to definitely want to find a saddle that fits you well, as in is wide enough to properly support your sit bones and has the right shape.
For me that saddle is the WTB Pure (used to be PureV), have been using them now on all my bikes for the last about 10 years and anyone I've loaned a bike to or let test one of my bikes has always liked them, a good place to start IMHO. If you're going to give them a try, get the lower end version without any stitching/pattern on the top, the lower end ones have a softer foam which most prefer - I have a high end version a friend swapped me because he hopped on my bike with the lower end Comp version and liked better.
WTB actually have a demo program that stores can sign up for where you can try out various models before you buy, would check in your area and see if maybe any shops have this. I've found when setting up WTB saddles that it's very important to make sure the sit bone area of the saddle is level, which in a lot of cases leaves the nose looking like it's pointing up some, don't worry about that. Also if you're on an FS, don't forget that the rear usually sags more than the front, so may need to set the saddle slightly nose down when you're off so it goes level when you sit and weight it.
