sounds good to me. had the same SID on mine and it worked great with that setup. I actually went a bit above body weight(personal preference)
That is about right. Depending on the terrain it may be like riding a hardtail. The nrs is a very responsive bike and with the no sag setup it is like a bullet. However, if you are riding in very rocky terrain your butt will be jumping off the saddle with every single rock. I set up mine with plenty of sag, both chambers about the same pressure. It is a less responsive but it gives me lots of traction.hannibal smith said:View attachment 508311
Crappy pic, and never mind the pedals (just for setup) but this is my NRS so far-
Flat Gray powdercoat frame
Fox forks 100mm
XTR hubs with DT Swiss XR4.2D wheels (very light)
XTR M952 drivetrain
Syncros seatpost
Easton EA70 lo-rise bars
Peeled off all the stickers and logos, so it is not flashy at all.
Anyway, the questions-
Rear shock is a stock SID, I weigh 200 pounds, so I am running 200 in the top chamber and 50 at the bottom, from what I gathered, this is correct for a no sag initial setup, I would appreciate some confirmation or even some setup tips from the experienced NRS owners out there-
BTW, this no sag setup is a first for me, so feeling no give when I sit down has me slightly baffled!
