1 - 20 of 31 Posts
Well, I thought that based on the general response last month to having the kits available that I would easily sell 8 (it was all I could get complete parts for). Turns out only 6 people needed the kits.
I was quite mistaken that this is something that NRS riders wanted. I will be parting out the remaining bearings (552) and bushings (465) that I have. I won't bother with the sleeves they are just to expensive for me to stock any amount.
See my ad in MTBR classifieds, with the link to eBay.
Later.
Discussion Starter · #2 · (Edited)
Got the Backordered polymer bushings. Rebuilt the NRS too.
460 to be exact. And the 600 bearing, well, actually 552 since I sold 8 kits. Seems the local manufacturers are doing decent business. I am having a difficult time getting the quotes for the spacer sleeves. The only supplier that has an equivalent part is overkill. I'll keep pestering the manufacturers , as I can lower the kit cost by $10 if they can be made for close to $1.00 each.
I also rebuilt the NRS. Rides like new.
Discussion Starter · #4 ·
Al. said:
I also rebuilt my NRS (2002) with your kit - and it does ride like new. The bearings behind the bottom bracket are a PIA to install though.
Thanks.
Very good to hear about the results! And yes, if the bearing starts slightly crooked into the bore, they can be difficult to press in. Especially the larger main pivot bearings. It's not impossible though. A little patience. Did you find the pictorial manual was OK? If you can recommend any changes, I would be glad to hear them.
John
Hooligan
I have replaced the rocker arm bearings previously, and cleaned the rear bushings, so I only referenced your manual for the bottom bracket bearings, which I had no experience with. The C clamp and a socket did the trick for those. I did not disassemble the entire rear end to do this, but worked on one part at a time.
First, I removed the swingarms (by the way, the SGF rocker arms use the same size bearings as the stock rocker arms) and replaced those bearings; I added new seals to my canecreek cloud nine while I was at it, then reinstalled the swingarms and the shock. Second, I replaced the bushings and sleeves in the back and reassembled. Finally, I disconnected the lower swingarm at the bottom bracket pivot and replaced the last bearings. Then tightened everything back up. I did not have to remove the rear derailleur this way.
Your manual was precise and complete. No complaints form me.
Discussion Starter · #7 ·
Response sent
Al. said:
Hey John,
I need some new bearings for the rocker arms, (2002 NRS, 2 pair) not a whole kit, do you still have those to sell, or could you list the size bearings I should order? thanks in advance.
I sent you a reply Al. No problem. Plenty left.
will these bearings fit the '01 or are they for the newer NRS
also how much for the complete kit?
No Brakes
Need set of bushings for '01 NRS
John,
Could you let me know the cost (kit + shipping to CA) and payment method? Thanks very much.
Al
Discussion Starter · #15 ·
No Brakes said:
John,
Al
Contact me at ( johndoiron at sbcglobal dot net ) . You can figure out my email address, I did it that way to fool spambots. Replace "at" with @ ect.
Payment usually through PayPal. One kit is $23.75, but two is only $30.54. I have a price list for up to 10 kits. Prices above are mailed First Class USPS.
Trail Sanitizer
John -
Please forgive the newb question but how do you change out the bearings? I have an '03 NRS and I'm switching out the rear shock (Cloud Nine) and rocker arm (SGF) so I thought I may as well swap out all the bearings while I'm at. However, I have no idea how to do it. What tools do you need? Assuming it's easy, I'll probably buy a couple of kits from you.
Discussion Starter · #17 ·
Posted this somewhere else but I forget where.
Bulldozer said:
John -
I think I posted this somewhere already. But here it is again. 2 ways to do it, the fast brutal way, and the slow careful way.
1) Fast way. Use a tapered punch through the center of the bearing and smack it out with a hammer. First Picture shows the teapered punch through the center of a rocker bearing.
2) Use a couple sockets and a large C-Clamp to press the bearing out slowly.
1 - 20 of 31 Posts
