What is the biggest tire [i.e. 2.4] an nrs frame can handle? front? back? Thanks
btw im new to mtbr. hello everyone!
I am running the 2.25 Geax blade which is bigger than most 2.4's I have seen so you should go 2.4 no problempntballpunk51 said:thanks for the reply
thx a lot gmaticgmatic said:I have about 4-5 mm clearance on either side of the chaistay and about 17 mm at the top (tread) part of the tire. The seatstay gives me about 5 mm each side and 17 mm at the top part of the tire. I run the tire at 35 psi in the rear. I've ridden in mud and gravel and haven't had any of the paint rub off on the inside of the stays yet. I guess there is enough clearance since there hasn't been any rub yet. I definitely couldn't go with a bigger tire than this on the back.
