1 - 1 of 1 Posts
a.k.a. MTBMaven
I have a Mavic XM 321 rim. Do I need the regular or freeride rim strip from NoTubes? I'm assuming the difference is the width of the strip.
Edit: Nevermind. The following information is from the NoTubes site.
" Rhyno Lite Kit\Rhyno Lite Rim Strip. You will need to use one layer of 17mm Velox rim tape underneath the Rim Strip and center it in the rim cavity. This will fill in the rim cavity, making the Rim Strip a little wider. The Rim Strip will not go up the sides of this rim, just make it look the same all around the rim. It will inflate easy." http://www.notubes.com/support_selecting.php
1 - 1 of 1 Posts
