1 - 14 of 14 Posts
· Registered
;) here is my Father's day ride in CO. http://forums.mtbr.com/showthread.php?t=202600
But I think I might have bent my seat stay?
Wheel Bicycle tire Bicycle wheel rim Mode of transport Spoke
I don't know when this might have happened, and I don't notice any handle problems, so I'll wait until the season is over (well, the slow season) to replace it, if no one thinks it is a problem.
· Ultra Ventanaphile
Correct, the load is compressive, same advice though, get it replaced.
Demo - no idea, especially not knowing what caused it. Probably the highest compression loads there.
Just an educated guess on my part.
Aaron
· Registered
Clearly the cause of unbalanced side loading imparted by the brake jack resultant of that suspension design.
Did you wheelie drop off something and land with the rear brake locked up?
· Registered
Discussion Starter · #10 ·
The other side looks fine, and I am not one to get much air.
I think it was caused by a rock kicking up, but it is odd that there is no damage to the chain stay.
I really don't know when this occured, it may have been months ago and I am only noticing it now.
I have a note into Ventana. I'm confident they will take care of me, but concerned I'll be without the ride for longer than I can stand, which is about a week considering we are hitting the peak of alpine riding in Colorado (see main point of this post).
· Registered
I had very similar damage in nearly the same location, though on mine the tubing bent more inward rather than backward. The part is called the "brake stay" and runs around $200. I continued to ride while waiting for the replacement in the mail so I did not miss any trail time. Making the replacement is pretty easy -- it takes maybe 1 hour and can be done with allen wrenches, though a torque wrench is nice if you want to be anal about torquing all the pivot bolts to spec.
On the positive side, the replacement brake stay eliminates the lower yin/yang cable guide -- which forces too much bend in the cable -- in favor of a zip tie guide higher up.
I did not press the case for warranty replacement, assuming it must have been something I did while riding, though seeing the photo of your bike makes me wonder if it could be just a coincidence?
· Registered
Discussion Starter · #14 ·
Thanks, excellent info. If I get a hold of Theresa I hope the part will be here next week.
Sherwood suggested that it was a stick of some size, since there are no gouge marks in the location of the bend. But you do have me wondering, if I got hung up on something enough to cause this damage, I'ld have replaced spokes ... I think. And I've never damaged a wheel on this bike to the extent it would bend the brake stay.
I rarely if ever bottom out, and I find it hard to believe rear braking has anything to do with it, since it locks up so easily.
Anyone else experience a similar issue?
1 - 14 of 14 Posts
