Hey guys. Not sure if this is a brake issue, fork issue (fox factory 34) or something else.
Two rides ago I noticed that I was getting some brake noise/rubbing of my front rotator ONLY when I was really applying heavy torque to the peddles, like while climbing hard. Doesn’t occur if I’m on flat ground and peddling hard though so it’s almost like I’m getting flex somewhere.
Doesn’t happen if I hold the front end up and spin the wheel. Doesn’t seem like there is flex/play in the wheel or hub (NOX carbon and DT 350).
Only thing that I have noticed recently is that when I spin my front axle in and then flip the quick release to lock it that the release is easier to flip than it was months ago (ie not as tight when clicked where it needs to be) almost like the axle needs to be adjusted etc. but again nothing seems loose when it’s tightened down and no play in the axle/hub.
Bike is a carbon Pivot Mach429 trail. Brakes perform the way they always have
Anything I should be worried about, adjust (I know the fox forks have an adjustment for the quick release axles so they will clock correctly) something else I should look at?
J-
J-
