Mounted up this brand new Specialized Slaughter rear tire - filled with a good amount of Stans (and shook the bottle to get all the rubber bits into the mix).
Rolled the wheel around in every direction - then went riding as I have found that usually a ride is the best way to get a tubeless tire to seal up.
It barely holds air pressure - pressure drops low in an hour or two and it pops off the bead overnight.
Put soap on the tire to check for leaks - hundreds of pinhole leaks - all the white spots in the photo.
I have used tubeless for a few years, and not sure if I am stupid or just buying junk tires, but seem to always have problems with leaking tires with pinholes. Thought i'd have better luck running what should be a quality tire.
Is this normal or should I send this tire back to specialized for warranty?
