When it comes to "hop" you have to be aware whether the hop is at the rim weld or not. If it is at the weld then some hop will probably always be there. If it's not at the weld then it was induced by the spokes not being tensioned equally. I talk about this in my sig info.
1mm trueness is a lot of wobble. If you've been playing around for a couple of hours then you probably have the tensions all out of whack and that isn't good. Tensions should be very close to equal.
Of course a "100% true wheel" is a dream and really not necessary anyway. Lots of us can get them easily within 0.003" - 0.010" (three to ten thou, where 3 thou is about the thickness of a piece of paper). But that level of trueness isn't beneficial. Equality of tension and acceptable overall tension is much more important. That plus stress and windup relief.
Yes the front rim needs moving over. If you have to ask that question then it concerns me as to what else you're not sure about. I'd strongly suggest you read my sig info and get Roger Musson's wheelbuilding e-book.
