1 - 2 of 2 Posts
Took rear wheel off to change tube and now my Juicy 3 brakes will not open back up to re-set the tire and rotoe back in place?what have I done wrong??need help desperate!!!:confused:
ride hard take risks
You squeezed the brake lever, you can try to get a flat blade screwdriver between the pads & twist to retract the pistons back into the caliper. If you are unable to do this then open the bleed hole to release pressure, you will have to bleed the system after this though. :thumbsup:
1 - 2 of 2 Posts
