1 - 8 of 8 Posts
I specify non-racing because I know cyclocross racing is a completely different story than my shmo'ing around on trails.
Locally, long'ish fire road climbs; technical rock trails that I will probably dismount for. But I also don't want to spin about on the roads and I also realize that the CX geometry climbs a little better than a MTB.
I'm thinking 38X22 - but that sounds really short, IMO. My fitness is middle of the road - maybe a little better. Anybody riding something similar to a 38X19 or 18 and do you find yourself grinding too much on climbs?
Again, this will not be used for racing - just trail riding. :)
I'm 38x20 on my beater rigid 26er. It gets pretty spinny on roads. Bout to put on a 18 and see if I can take it on the longer climbs and tech stuff cause its more of a hop on and ride around the block and down to the bay kinda bike anyways.
I ride 36-17 fixed on my cyclocross bike. I do however find myself walking some climbs I should be able to ride. It however is the bike I ride to the trail head, and then the trail. Much shorter and I am spinning too much on streets. I could run something shorter if I were on the freewheel. 36-19 or 20 would work out. Its closer to what I ride on my mtb for trail use only.
Discussion Starter · #6 ·
On a 700c X 32 (170mm cranks), a 36X20 gearing measures out about 48.6 gear inches
I've settled on my 38X22 which measures out as 46.6 gear inches. I have a 19T White Industries freewheel I can spin on the other side if needed. My current 22T is White Industries, as well :D
Yes, it's short, but our local trails are climb'y and plus I'd like to be able to climb the bigger road hills. Thanks for your input.
Shred...it's the new drug
just ripped up Desert Classic out here in Phoenix with 32-16. I'm not a avid SSr but after today's jaunt the squishy geared bike might be getting a little dusty:) I made all the climbs that I usually make with my geared and only walked the ones I can't make with that silly deraillur. It was ripping good!!!
Discussion Starter · #8 ·
Are you riding a cyclocross bike?
I have a 29'er singlespeed (32X22 - it get's steep where I ride and I hate walking) that is my preferred bike out of the 3 MTB's I have. I'm a pretty avid single-speeder (I also ride fixed, 48X16 on the road and can climb pretty well on that bike :D). In my past, I've gone 34X16 on 26" wheels.
Just for clarification, a cyclocross single-speed is a WHOLE different beast than a single-speed MTB. For one, you're dealing with a different wheel size, skinny 700C X 32 tires... and for two, you're dealing with an extremely different geometry set-up, let alone drop bars. I know for a fact that I will NOT be taking this bike on all the mountain bike trails I ride - especially the super duper technical stuff. It's a tough call because I still want to be fast on the road and hardpack flats, but I want to be able to rock flowing singletracks.
1 - 8 of 8 Posts
