1 - 9 of 9 Posts
Are there any Bontrager rims that are TLR but not OSB? And 32 hole? The only ones I've seen people building with are the Dusters. I can't tell from the bontrager site or the trek site if non-OSB rims are available to buy.
Thanks for any info.
Premium Member
AFAIK the 29" TLR rims are all OSB and only the Duster is 32 hole.
This place needs an enema
I don't think so--I've only ever seen TLR and OSB together.
Both Dusters and Mustang Disc are available in 32h, TLR, and yes, OSB.
Why would you NOT want OSB?
MC
Premium Member
MC
When using a single speed hub that has equal flange spacing. Most are still slightly off center though.
Discussion Starter · #6 ·
MC
Cuz I have a 240s SS centerlock hub, and I believe that makes an undished wheel ? At least it seems like it does looking at the one I have here (that you built a few years ago for me) And so it would seem like a bad idea to lace it to a rim designed to compensate for different length spokes. Lemme know if I got that wrong.
EDIT: yeah, what Shiggy said (i didn't see his post)
I assumed the same thing until I actually measured tension on *both* sides of a finished wheel. Using your hub and any on-center drilled rim the disc side ends up with marginally higher tension. Build it with the OSB rim and you'll have a minor tension imbalance but still much better than a 9spd hub laced to an on-center rim.
In short, OSB + 240s SS = :thumbsup:
MC
1 - 9 of 9 Posts
