mototech said:
Benz, I would say I do it all. My Joker has a heavy duty build- 38.5 pounds, 7" travel front and rear. I ride drops and ladders, horse trails, cross country trails, even some street. Whatever it is though it will be an agressive ride. I have no problem putting in 30+ mile days with a little bit of everything thrown in. Climbing is no problem either- most climbs are steep but not very long. How is your Nomad set up?
OK Moto - Ive come from the other end of the scale - my other bike is a blur classic at 27 pounds!!
My set-up is large grey ano -
Fox DHX Air
Fox 36RC2
XT cranks, Front DR & shifters
XTR rear
Hope mono M4 - 8" front 7" rear - braided hoses
Mavic 321 plus kenda
Easton Vise and EA70 bars
Thomson post
Weighs in a fraction over 32 pounds - most of my riding is in the jungles as I live in south east asia - quite technical, mix of of rocks, roots, technical downhills and similar climbing - short and sharp - no long fire road stuff like back home downunder.
After riding a blur for three years I did notice the weight penalty when I first started riding the Nomad (anyone that tells you otherwise is full of #@$%). Also the rear end is far more active than the blur setup which is more XC focused.
But - I have had the Nomad for 2 months and I have hardly ridden the Blur at all - the nomad climbs really well - seems to stay hooked up and whilst its no XC bike it is just such a pleasure to ride that you forget the weight quickly - I expect that coming from your joker you could build a 34-35 pound Nomad that is bulletproof.
I expected the front wheel to be quite vague and initially i would wind the travel down on longer climbs but havent experienced that - although climbing on a VPP did take me a while to get dialled in - its all about staying seated with your weight as far forward as possible. Downhill this bike is unreal - end of story.
With regard to the frame size I would recommend going for the larger frame and fit with shorter stem etc - will give you more positive feel - and awesome stability.
Basically the Nomad is an amazing ride.....
Let me know if you want more detail....
Benz
