Nomad 2 / Manitou evolver isx-6 setup?
960 Views 5 Replies 4 Participants Last post by  mullet dew
Please can you type your setings on manitou evolver isx-6 /Nomad 2
Rider weight :
IFP (small chamber)
SAG (main chamber)
Rebound
LSC
HSC
Volume adjuster
1 - 6 of 6 Posts
Rider weight :210
IFP (small chamber)70psi
SAG (main chamber)165psi-20mm sag
Rebound
LSC2 clicks
HSC1 click
Volume adjuster1
Mine is more of a dh set up,with a totem solo air up front.
x post from another thread on ISX-6
Similar setup query as OPs post here:
This question goes to users of the Manitou ISX-6 on a Nomad Mk2 alu, specifically and on other VPP bikes in general.
Some info to put it in context: On my ride last ride, on mostly AM trails, I noticed for the first time after installing the ISX-6, that on landing after bigger drops/stairs/jumps on higher speed, the rear wheel was rubbing on the seat tube of my Nomad. :nono:
I wouldn't have noticed it, until I actually heard the sound on the tire rubbing on metal, on the video that one of my riding mates shot (maybe about 6ft. drop), see below (pay attention to 00:13-00:16):
Then I looked at the decals I have on the seat tube and there are partly peeled off, from frequent contact with the rear tire. Doing my usual drops of about 4-5ft., I always have about 5% of travel still left on the rear shock. But now on the bigger drops my rear tire (Maxxis HighRoller 2.35 LUST) is rubbing on my seat tube. :rolleyes:
My current setup is 90PSI on the IFP, and 170PSI on the main can, with 3 clicks of LSC and 3 clicks of HSC and bottom out at 2, fully kitted, about 210lbs (92kg).
Has anyone faced a similar situation before?
What should I change in my rear shock setup so as, the real wheel does not touch the seat tube on larger drops/jumps?
Try bottom out at 3. or maybe increase HSC
Your setup in Rebound?
Thanks mate, I will try these suggestions.
You should measure the shock to make sure its the right length, should be 8.5"(216mm) long from the center to center of each eyelet, with 2.5"(63.5mm) of shock shaft showing. I run a 2.5 Minion DHF and I have never buzzed the seat tube, but I have a completely different shock.
1 - 6 of 6 Posts
