My Nokians finally arrived on Monday and I have had the opportunity to compare them to the RRs . I tested both sets on the Epic.
Weight:
RR-452,491g
Nokian-477,479g
First- the Nokians mount very easily. No tire levers required, just a little persuasion with the fingers. A plus if you need to change a tube in a race.
Rolling Resistance: TIE
Both tires roll very fast. It would be difficult for me to say one was quicker than the other, but both were noticeably faster than the Python Airlights. With both tires, easing off the brakes in certain sections gives you the sensation of accelerating. Both exceptional!
Cornering- NOKIAN NBX LITE
A week ago I would have bet that the RR was the best cornering tire available..not now. The Nokian doesn't seem to have a limit as to how hard you can carve into a turn. Even later into the ride I intentionally took some of the S-bends too fast with the intention of having this tire drift, plow, wash-out...this never happened. It is very confidence inspiring. In a few turns there was tiny bits of twigs and leaves and the Nokian tracked true through them all.
Wet sections- NOKIAN NBX LITE
Through the wet section of the course (maybe a couple hundred feet) the Nokian did a great job. The knobs shed the mud quickly. Through this section last week the RR packed up immediately. Right after the wet section is a 100yd long flat section with very small rock and pebbles, the RR picked up a ton of the rocks and made the tires feel like concrete, I had to unclip and use my shoe to clean the tire as I rolled along. The second lap packed on enough mud to slow the tire from having all the mud jammed in the chain stays and brakes.
Off camber and Ruts- SCWALBE RR
The Nokian really felt sketchy here. Ruts were the biggest problem. The Nokians don't really like to traverse the ruts at any angle but rather follow them. Same when on the off-camber stuff. Some parts of the trail make the "U"-shape with the banks on the side and the Nokian felt horrible. It did not feel like holding a spot on the bank. The Nokians felt slow and unresponsive (@ 1 point I checked to see if the front had punctured), which was very surprising given that the side treads did so well in the turns.
Right now the nod goes to the Nokian NBX LITE. Unfortunately, I can already tell that the Nokian is going to wear much faster. The compound is very soft.
I hope this helps, seeing that these seem to be the two WW racing tires at the moment.
XC
Weight:
RR-452,491g
Nokian-477,479g
XC
