1 - 17 of 17 Posts
Looking for some help for determining chainstay clearance prior to buying tires.
Can someone please give me diameter measurements for a 26" Nokian Gazzalodi 3.0 mounted and inflated wheelset please?
Also, do you get a true 3" tread, if so what width rim are you running?
Can't get right...
They r pretty wide!. Rim width determines how big it actually is. What frame r u planning on putting this tire on? my friend had a 26 Doublewide rim w/ 3.0 fit on his super 8 but that was a tight fit. Icouldnt do it with a 26 so went down to a 24. It depends on the frame really. sorry i have no measurements cause my gazz is sitting on the wall unmounted.
Glad to Be Alive
IMO...it is worthless to run that big of a tire....it is too big to roll so it makes pedaling harder....do yourself a favor and get the Michelin 2.8 32AT....smaller and better rolling....How much do you weigh anyway??
Discussion Starter · #4 ·
This is for a snowbike that I'm building and am looking for the floatation. It's going on a SS Blacksheep Ti custom 29er that "should" have the clearance necessary, but I want to be certain before buying the tires and building the wheels up. Thanks for any assistance.
Glad to Be Alive
my bad...PM Dewey...he rides in the snow all the time
http://forums.mtbr.com/member.php?u=239379
Meh.
It's [email protected] wide. Possibly even wider than a true 3.0. I run them on 36 mm Halo SAS wheels. I run the 24 inch version though. It's heavy though. REALLY heavy. It's not worth it. The traction seems dodgy at times. And there's definitely a lot of flex since it has insanely tall sidewalls. I still have 2 of the 24s sitting in my room with like 70 percent tread. They were just too heavy. I ended up throwing on Hookworms for getting around. And have a 2.6 Gazzi for the rear and a 2.75 Arrow Racing Prime Bite in the front. They track extremely well. I love the Arrow Racing tires.
Premium Member
Quick specs Gazzi 26x3.0 on a HED DH 45mm rim @ ~30psi:
Casing and tread width 71.5mm/2.84"
radius to widest point tread 346mm
radius to top of tread 356mm (diameter 712mm/28")
SNOWRIDER
SHIVER ME TIMBERS said:
Si' Senor....but you probably had the most knowledge that is why i sent him to you
I haven't run the Nokians I run the Michies on my dh bike Sorry :(
1 - 17 of 17 Posts
