1 - 8 of 8 Posts
I guess most people switch from V-brakes to Disc, but I'm doing the opposite. I bought the bike with Disc brakes, but they are heavy and I have no use for them as I don't ride downhill or in mud.
Looking for V-brakes recommendations.
I just moved in the opposite direction that you're going. I had the cheap tecktro V's that came on my Rockhopper. Even after one year they would send me over the bars if I wanted them to lock up - on the road too. I'm not sure that you'll get much more out of an expensive set other than saving weight. Just my opinion.
Avid SD7's with Kool Stop MTB pads have been working beautifully for me. SD7's and a lot better than the SD5's by a long shot. I have 3 sets on three bikes and my only problem has been the rim wrangler pads which I am phasing out as they wear out.
You couldn't pay me to go back to disc brakes again.
local trails rider
Anything with Koolstop pads. Also make sure your cables are good.
I think the Shimano parallel linkages are an expensive solution to a non-existing problem.
bi-winning
I was going to say, that I think pad compound (as well as the finish on the braking surface of the rim) plays a very large roll in dictating the performance of V brakes.
My SD-7 with speed-dial levers always treated me well; as long as the ride was dry.
Much better then the LX V-brakes I had on my other bike.
1 - 8 of 8 Posts
