Yes and maybe change your tubes too just in case.
J/K if it ain't broke, don't fix it. Unless you're bored or you want to try those Push bushings or something.
Some folks swap around the pivot shafts, as the BB pivot gets the most wear. That will extend the life of the whole set.
You might want to grease the pivots more than a couple of times a year but it's not critical esp if you're not having problems.
