erm..the properties of carbon? and custom geometry? pls correct me if i am wrong..Jayem said:What advantage would it have?
the pounding would break it...I don't think it would last longmafia6 said:seems like no one is making them huh? custom carbon hardtails are hard to find too..or maybe i havent searched hard enuff?![]()
They're out there. Depends on how much and what kind of riding you'll be doing.mafia6 said:seems like no one is making them huh? custom carbon hardtails are hard to find too..or maybe i havent searched hard enuff?![]()
Scott and (presumably) Ibis are stock models only - no custom option as the OP was referring to. Trek Fuel is obviously another stock carbon FS option.Rumpfy said:They're out there. Depends on how much and what kind of riding you'll be doing.
Scott USA
Ibis Cycles
Titus?Circlip said:Does anyone else know of options even for custom aluminum FS XC?
Titus does custom Ti, but not custom aluminum.Hosehead said:Titus?
that I've found is Curtlo. You get a custom steel front triangle with any Ventana rear configuration for $1475. Doug does full sus 29'ers too.meloh1 said:Serrota has one http://www.serotta.com/pages/ottrott_xc.html
MUCHO dollars!
Seven has one http://www.sevencycles.com/bikes/imx.html
MUCHO dollars!
Steelman will probably do one for you http://www.steelmancycles.com/signature.html
Pricey but more reasonable.
Titus will do one http://www.titusti.com/custom.html
Price?
There's probably others.
Oooh, you mean custom custom. My bad. I'm not sure who does that kind of work.Circlip said:Scott and (presumably) Ibis are stock models only - no custom option as the OP was referring to. Trek Fuel is obviously another stock carbon FS option.
Before asking where the manufacturers are of custom carbon FS frames, I think you should ask how many will even do a custom alumninum frame. Ventana does it. I had my Yeti ASR-SL done with custom geometry for a small upcharge about 3 years ago, but I believe they have removed their custom option now.
Uhhh, huh?SHIVER ME TIMBERS said:the pounding would break it...I don't think it would last long
