26 x 5". 320 studs per tire. Folding bead. 120tpi casing. Brand new.
Not everyone needs what these bring to the table.
If you do, you do.
$500 for the pair includes shipping to a lower 48 address.
Happy to ship to Canada or AK, but shipping will cost more.
Contact: [email protected]
P.S. I have 18 of these in inventory. Terrene isn't bringing any more in this winter, so those 18 are it until late '22 -- act accordingly.
mikesee, you have any non studded?
thanks!
These actually offer good levels of rear grip, when in powder, you can actually mount and start riding; D5's I found just spun out when you were trying to mount your bike on any type of incline. And any notion of really powering over anything, again D5's spun out. Don't get me wrong, D5's are a great tyre the majority of the time out of snow, and if you ride exclusively groomed / walked trails then they perhaps may work for you. But I ride 98% forest tracks that are virgin snow and these made riding far easier. Two things that are draw backs, one, I do think Johnny 5's lack is lateral grip on the front, they can wash out, but correct pressures and ride with this in mind on off camber sections and they work. Second they are big tyres and with that comes some weight. I'd take both these drawbacks over a D5 (for my riding) every day of the week.What kind of night and day difference? I'm currently looking at buying some studded D5s.
Are your Wrathchilds studded?Wrathchilds are real grippy, no doubt. On ice, they outperformed anything I have tried. But for deep snow or powder, J5 is better.
For what I do ride, I choose Wrathchild. But there are times where I would like to run J5.
Ran all my tyres on 82mm rim, you still get large performance gains on a 'narrower' rim. Also have tried both the 60tpi and 120tpi D5's; noted the 60tpi really doesn't like the cold, it was very stiff on the sidewall and actually burped a fair few times making me cautious in running really low pressures with them too (This would improve once the sealant 'glued' the tyre to rim)... To get the most out of a J5, I’d start at around 90mm and say 90-100 is probably optimal. The D5 works well around 80-90. It kinda sucks around 65.
l’ve got D5’s that I tried numerous times on Clownshoes and they just aren’t wide enough to float for my conditions. They also lack the traction I need so J5’s replaced them. They do roll fast and work well on hard packed trails. Too limited for my needs though.J5 is next level compared to wraths and D5s. Next level float. Next level ice grip (maybe 2 levels). Next level rotational mass.
Just as important as the tire width is the rim, I’d take a D5 on a 90mm well before a J5 on a 75mm for all around performance in soft snow. The profile of the D5 will work better with that rim to tire ratio. To get the most out of a J5, I’d start at around 90mm and say 90-100 is probably optimal. The D5 works well around 80-90. It kinda sucks around 65.
Yes. They excel in loose snow. But the Wrathchild is also a good tire in loose snow. Just less rubber and less floaty. So arguably less good? But...if you don't have enough loose snow or enough deep snow, you will suffer in sweat equity for dragging the J5s around.So sounds like J5's grip better in loose snow than Wrathchilds?
Yes, I can imagine the crappy Vee tires are sketchy. Personally? I'd suggest something like the D5 if she's mostly riding straight forward trails and logging roads with some snow and/or ice. A lot of folks run the Dillinger in reverse on the rear for climbing grip. Worried about front wheel washouts? Put a Wrathchild on the front. Damn the torpedos and more grip all around? Wrathchild front and rear.I'm looking for replacement tires for the crappy Vee tires on my girls new fat bike. She wants a studded tire and would be riding groomed trails and occasionally ride some new snowfall (1-4") out back of the house or some old logging roads She is not the most skilled rider at this fat bike thing and it terrifies her when the tires slip because she is scared of crashing. So looking to purchase a studded ~4.8" tire with the best grip in both groomed and loose snow.
I have the dunderbeist and flowbeist on my bike and they suit my needs just fine.
Snow sticks to them and traction is lost.Ive been riding the “crappy Vee tires” (Snow Avalanche studded) and have yet to see where they are all that crappy. They do what I need them to as long as I have the air pressure dialed. No, they aren’t the best out there, but I just don’t see where they are all,that “crappy”.
