tom schoonveld said:
I too have a reign 1.
A year ago you couldn,t give me a manituo product but they have really stepped up their game. I have had a couple of minor problems that were IMMEDIATELY taken care of by answer and none of this you pay the shipping crap I have heard from other fork manufacturers they should be a shamed to sell a product that is bad out of the box and ask the customer to pay shipping. Any way I had a question while I am pleased with the performance I am having trouble finding that sweetspot with the fork. I have been toying with spv and main air spring pressures and can't seem to get that spot. The fork performs well but I would like to find that compromise were it performs well in most situations.
Thanks for any help.
Tom
Tom,
Another positive trait of the Nixon, is that its performance seems to be getting better the more I use it. Did not mention it in my initial post 'cause I thought it may sound as wishful thinking, but after reading Mr P's post, well it may just be true. Possible reasons:
1. Extremely long break in period
2. User learning process of its performance behavior
3. both
As I stated first, it is not as sensitive to small bumps as other forks, but it seems to be getting a bit better, although it would never feel as other very small bump sensitive forks.
I set it up when I first got the bike, My settings goal is for aggressive XC medium to fast speed, gnarly terrain. Not to many downhills (many big sharp impacts) around and no jumping.
Air pressure, the least for my wt of 150lbs
The air pressure is tricky, I left the pump put as I activated the IT switch and tried to make the pressure uniform at different shaft heights: at minus 1", at minus 2" etc etc.
until pressure reading was the same at any travel setting.
SPV pressure. Did I have a scare with this!!! Initially it was almost no pressure, and the fork would make small clank noise as it rose. Discovered that on my first ride and felt myself getting pale, felt my skin getting cold and my blood pressure descending, A BRAND NEW (EXPENSIVE) PRODUCT WITH UNHEALTHY NOISE.
Well there is a minimum pressure that has to be on the SPV chamber otherwise the small clank upon returning. I use the minimum SPV pressure I can get away with.
Rebound, I usually use the least possible damping (returns faster)
I have not touched the compression progressivenes setting, I beleive it is an internal setting, but would like to have it the least progressive as possible (more linear)
I too am on my "quest for the holy grail" concerning suspension performance, hope this helps
