Honestly man I don't know what the heck I'm doing. I like to ride trails, my friends like to ride gnarly freeride-ish trails. I am torn right now between light and snappy and heavy and bomber. If I could find a happy middle ground then I would be cool. Something tells me I am on the right frame, I just wish I could have the option of having 6 inches of travel without the added weight. I would run it at 5 most of the time but crank it up to 6 for the shuttle days, ideally I would only have one fork to do all this. Right now, I think the only forks to do this are the duc32, and the AM1. The AM SL seems pretty sweet, its not too much heavier than my vanilla, I am assuming it will be stouter than my nilla (less flex) and it will have all those nifty TST,ETA,LMNOP features. the only thing is I am not sure if it is extendable to 150mm without having to change anything internally.KDK said:Hey Smokes, you are asking too many "fork questions". Are you thinking of ditching you Z1 ?
smokey I've tried that "convertible" route before and just got frustrated like you are talking about.SMOKEY said:Honestly man I don't know what the heck I'm doing. I like to ride trails, my friends like to ride gnarly freeride-ish trails. I am torn right now between light and snappy and heavy and bomber. If I could find a happy middle ground then I would be cool. Something tells me I am on the right frame, I just wish I could have the option of having 6 inches of travel without the added weight. I would run it at 5 most of the time but crank it up to 6 for the shuttle days, ideally I would only have one fork to do all this. Right now, I think the only forks to do this are the duc32, and the AM1. The AM SL seems pretty sweet, its not too much heavier than my vanilla, I am assuming it will be stouter than my nilla (less flex) and it will have all those nifty TST,ETA,LMNOP features. the only thing is I am not sure if it is extendable to 150mm without having to change anything internally.
After having waited forever for heavy springs and changing my fork/stem/wheel/brake combo every other day according to the trails I ride I have decided that I don't like having 2 forks. ITs a pita. I wish I could have 2 bikes but my budget (and wife) are reigning supreme over me right now. Bummer.
........yes indeedy! The only glaring incompatibility between Z1 & AM seems to be the circlipped assembly the 05 Z1 has in the lower right stantion...because the AM stantions do NOT have the groove on the lower inside lip to accomodate the c-clip. The 04 Z1(130mm) doesn't have this C-clip assembly, but does share the grooved stantions......other than that the 03 Z1 ---> 05 AM swap-over should be cake!gonzostrike said:SSINGA,
will '03 Z1 FR QR20 lowers work with '05 AM 1 stanchions, internals, etc?
Just incase no one else has mentioned it, it's worth noting that the AM SL does NOT have ETA. So you won't be able to lower the fork when climbing. Definitely worth thinking about if you do lots of steep climbs as this is a tall fork.SMOKEY said:The AM SL seems pretty sweet, its not too much heavier than my vanilla, I am assuming it will be stouter than my nilla (less flex) and it will have all those nifty TST,ETA,LMNOP features. the only thing is I am not sure if it is extendable to 150mm without having to change anything internally.
04 Z1 FR and the 05 Z1 FR1 have the same adjustments - the only difference is 20mm more travel in the 05.KDK said:I am too in search of the 'perfect fork'![]()
I would love to get the AM1 with all the adjustment goodies but would like a 20mm axle and HATE that colour. The Nixon appears very promising but it does not have the thumbs up from the Homers. The '04 Z1 looks ok but does not have the AM1 goodies, and the' 05 Z1 has even less adjustments than the '04.
The Pike is very new and support where I am is sketchy, and the Firefly is perhaps too much for the Spot ? The Foxes (TALAS, Vanilla) do not approve 8" rotors while the 36 is way too much for the Spot.
I guess I'll stick to my 04 Minute 1 and ride the crap out of it until Marz come out with a 20mm AM1 in black![]()
Yes but isn't 150mm too much for the Spot?SSINGA said:04 Z1 FR and the 05 Z1 FR1 have the same adjustments - the only difference is 20mm more travel in the 05.
I did not know that. ThanksSSINGA said:Fox does allow 8" rotors with the newly designed 05 drop-outs for the 32mm forks
Thanks for the offer but I live on the other side of the Atlantic (and beyond) and it is going to be too much trouble. But hey ! do you have an infinite stock of black lowers ??SSINGA said:Why not make your own Black AM1 with a 20mm thru axle? If your not comfortable with that I can make one for you.
Do not really need.... just a bad case of UGI I guessSSINGA said:PS - the std axle, 32mm stanchion AM1 is going to be waaaaaaaaaaay stiffer than a 30mm stanchion Minute 1. Why the need for the 20 mm axle?
Greece is close enough to Italy - drop by the factory and pick up some new lowersKDK said:Yes but isn't 150mm too much for the Spot?
Thanks for the offer but I live on the other side of the Atlantic (and beyond) and it is going to be too much trouble. But hey ! do you have an infinite stock of black lowers ??![]()
Do not really need.... just a bad case of UGI I guess![]()
