I haven't seen much about this light here, and was ordering something else from Perfomance, and had a coupon....So I ordered one to play with. My plan was to try to 'turbocharge' it by upgrading the LED and maybe the battery. I figured others here might be interested as it looks like a decent all-in-one light. It was of course on backorder, but finally arrived yesterday.
So I dug in today to check out the guts and see what could be upgraded. Below are the first pictures.
The LED looks like a Seoul P4 to me, on a round 20mm PCB. There are some spots for resistors and stuff on the board, but they don't seem to be populated. Maybe they are used on the 150 lumen version?
The reflector is also 20mm diameter and about 16mm long.
The upper PCB has a a small pushbutton switch and small red and green LEDs on either side for power/battery info.
The lower PCB has all of the driver electronics on it, with 2 wires going to the LED PCB. The charge connector is on the back of this board, and is one of those mini USB connectors that most digicams use these days.
The battery is a single lithium 18650 cell, labeled 2800Mah. So it looks like the battery is not worth upgrading until higher capacity units are available. What are the current best ones, 3000Mah? The battery is not soldered and can easily be replaced once the unit is apart. Not something you would want to do while riding, as it requires removing 3 M2.5 screws.
The battery is still charging, so no beamshots or voltage specs yet, but they will come.
If anyone wants more info or measurements, just let me know!
BTW, how much current would it take to get 250 lumens from a P4?
I'm thinking an XM-L might get me more light and even longer run times. Run time is quoted at 2:30 on high.
Mark
Mark
