This bike is amazing. Does anyone know the estimated weight of the complete shown? Also, what are everyone's comments about the bike?
davesauvageau said:This bike is amazing. Does anyone know the estimated weight of the complete shown? Also, what are everyone's comments about the bike?
The Bike in the picture is a prototype, and weights around 18.75lbs as pictured without pedal. This is a Prototype/ show bike and it does have tubes in the tires. The production model is targeted around the same weight.
The Carbon AIR9 has the CYA bottom bracket design, so it can be run as a single speed, or with BB30, BB90, or standard outboard bearing. The front and the rear dérailleur cable are internally run, to give it a clean look.
Check out our website for more info: http://www.ninerbikes.com/fly.aspx?layout=bikes&taxid=271
Hope this helps.
They use the same STA on all their other XL hardtails and they still seen to be quite populardirtrider7 said:Mike,
Beautiful bike. If you have four separate carbon fiber frame molds for that bike to lay up four dedicated frame sizes, why on earth did you spec the frame of the bike for XL with a seat tube angle of 73 degrees? Most XL rides including me have long femurs and 73 degrees for a long legged rider puts the rider too forward of the BB without an extreme setback seatpost. Only a guess on my part is your molds share the same rear triangle geometry. But unless your tooling is interchangable, I don't understand why you wouldn't revise the seat tube angle for the XL in particular.
Thanks for any comments.
You can get the same amount of pain for a lot less $$$$. Just pick up a Karate Monkey with the rigid KM fork and teach your kidney's, lower back, neck, arms and innards a serious lesson.G-Live said:As much of a fan of GF and their Superfly's, If I ever decide to pony up big $ for a dedicated rigid bike, this will be it. The frame/fork combo and looks of the bike would be too much for me to pass up.
G
Sounds perfect for a road ride....mattkock said:I've got mine on order and I've revised my build list too many times to remember but here's how it looks as of now, things may change before I get it in June.
air 9 carbon frame................1292g
niner carbon fork................... 550g
fsa internal headset w/ carbon cap and alu bolt..............75g
monkeylite bar 31.6...............165g
kcnc ti pro post.....................175g
fsa 99 stem..........................104g
carbon edge saddle...............112g
titec grips...............................18g
sweetwings cranks & bb.........600g
salsa 22t ring.........................25g
fsa bolts.................................8g
chris king 12t cog...................15g
kmc x9sl chain.......................200g
crank bros 4 ti pedals.............167g
formula r1 brakes....................354g
scrub rotors............................116g
ti rotor bolts.............................12g
stans 29er race wheels w/o yellow tape of valves.............1326g
rox rim tape............................6g
forte lunar light tubes...............190g
furious fred tires.......................670g
control tech ti and scandium skewers...............26g
total...6206g = 13.68lbs...........give or take a few tenths, we'll see. I'll post an entire build thread when the frame comes in.
Ooh, I want one of those posters!BruceBrown said:Just get the poster of the orange and black Air 9 Carbon and fork and hang it on your wall.![]()
Scrubs are fine if you live and race in the desert, but for those of us who live where it rains so that mud and water are a part of the race scene - I would rate them suspect for longevity and from a price to performance ratio. I don't know, maybe you live in dry climate...mattkock said:I have scrubs and Freds on my 26er and they're working just fine so I'll keep 'em but thanks.
Maybe among 6'3" guys with 32" inseam or guys that don't know any better.boomn said:They use the same STA on all their other XL hardtails and they still seen to be quite popular
My inseam is 38.75", and I am a hair under 6'6". I own two XL Niners (RIP and Sir), and used to have an XL Jet, all seam(ed) to work well for me with no setback posts or slammed rails. YMMV of course. Sorry, I forgot to mention that this is my Pro Review.dirtrider7 said:Maybe among 6'3" guys with 32" inseam or guys that don't know any better.
I can't or don't want to ride it. You will be in front of KOPS with a 34-36" inseam on a 73 deg. sta which is the statistical norm of a XL size rider.
Making a bike with all the same seat tube angle/rear triangle for all frame sizes the same to me smacks of cost cutting to conserve molding geometry.
Well, then you've got to rag on Salsa, Surly, Lenz, Ventana, Specialized, etc... as well since they all do the dirty deed.dirtrider7 said:Making a bike with all the same seat tube angle/rear triangle for all frame sizes the same to me smacks of cost cutting to conserve molding geometry.
oh, i'd never pull that big of a tri$$er on a rigid bike. (I do have a zion ss rigid I got for $125 frame/fork). But if $$ was no object and I wanted one this would be it.BruceBrown said:You can get the same amount of pain for a lot less $$$$. Just pick up a Karate Monkey with the rigid KM fork and teach your kidney's, lower back, neck, arms and innards a serious lesson.Sure, it'll weigh about 3-4 pounds more, but there's no need to spend over $2K on a carbon frame and matching fork to find out your innards and core need a big ole multi-day rest after a rough ride. :nono:
BB
P.S. Of course, if you'd be willing to run a suspension fork on that carbon frame I would understand....![]()
You must ride it like a time trial bike with your femur length.gfs69 said:My inseam is 38.75", and I am a hair under 6'6". I own two XL Niners (RIP and Sir), and used to have an XL Jet, all seam(ed) to work well for me with no setback posts or slammed rails. YMMV of course. Sorry, I forgot to mention that this is my Pro Review.
Honestly, the reach for me is great, but I wouldn't mind a few more cm's of head tube! My custom roadie has a 270mm head tube. Yep, freak bike. :thumbsup: Oh, and I did have a custom with a really long TT, 26.5", and I much prefer a less stretched out position. But hey, that's me. Look, two Pro Reviews in one day.dirtrider7 said:You must ride it like a time trial bike with your femur length.If you ever get a chance, find a bike with a 70-71 deg sta with your monster length legs and you will then know what its like to have much less weight on your hands and be more comfortable. With almost a 39" inseam if ever there was a need for a custom, you are a good candidate as you are 99% in size with your leg length and pedestrian torso length. A guy 7' tall can ride a size medium frame as well but doesn't mean its the best fit is the point.
