looking for a good lighting system that mounts to helmet, not for commuting but for trail riding...two - three hours maybe....
what worx...thanks
what worx...thanks
ok, i was checking JET out...expensive but if it really worx i will pony up...your experiences is stuff i was after...thanks...could one get away with just running a 20 spot light on the helmet? thanksWish I Were Riding said:http://www.jetlites.com/2005products.html
I bought a 6 volt first, and then added a 13 volt later. Jim at Jetlites is really good about answering questions too.
I wish that I had gotten both 13 volt lights. I also find that my personal taste for the way I wish to use my lights does differ from what Jim originally recommended. If I could do it over, I would have gotten a 20 watt flood for the bar, and a 12 watt spot for my helmet.
Right now I use the 6 volt on the handlebar, and the 13 volt on the helmet. My helmet sometimes washes out the handlebar light, which sucks. I wish I had the spot on the helmet so that the light could pierce farther into the dark. Right now, when I'm going fast downhill, I find that I have to move my head from side to side in order to see upcoming turns better.
You could get away with it, but there are downsides to running just a helmet light. Light from the helmet will reflect back (unfavorabley) if you are following someone who is kicking up dirt, off rain, and is bothersome in fog. The angle of light to the ground is also pretty steep and that causes shadows on the ground (behind objects) to seem smaller than they really are. That is why a good bar light really helps too. But again, yeah, you could just get one helmet light. Oh, I just read that you said 20 watt Spot only, I think I'd get a flood if I only used one light for sure.adamantane said:ok, i was checking JET out...expensive but if it really worx i will pony up...your experiences is stuff i was after...thanks...could one get away with just running a 20 spot light on the helmet? thanks
While I have never personally experienced the reflection issues described here, the point of a two light system is very valid. A flood light on the bars to light up the area directly in front of the bike along with a spot on the helmet is the ideal combination, IMO. If you can only go with one, the helmet light is the way to go, as you need the flexibility of being able to shine the beam ahead of you, to the side, directly in front, or wherever you need the light to shine in the line you are taking. Bar lights shine wherever the bike is pointed, period.Wish I Were Riding said:You could get away with it, but there are downsides to running just a helmet light. Light from the helmet will reflect back (unfavorabley) if you are following someone who is kicking up dirt, off rain, and is bothersome in fog. The angle of light to the ground is also pretty steep and that causes shadows on the ground (behind objects) to seem smaller than they really are. That is why a good bar light really helps too. But again, yeah, you could just get one helmet light. Oh, I just read that you said 20 watt Spot only, I think I'd get a flood if I only used one light for sure.
This is why (even though I don't own yet) I would prefer a nice flood on the bar, and a spot light on the helmet to see further down the trail (and towards those creepy noises too).
LED's are really cool, like the Cateye Double and Triple Shots. Many people say HID's are the only way to go. Those all seem to cost a lot as well. For me, the Jetlite Halogens are just fine. I can go stupid fast with them, and I haven't had any problems.
Good luck!
