correct, if you plan on running a 1 1/8" fork you will need a reducer cup in the bottom.
Yeah, I agree...stupid! It sounds like I need a 1 1/8 cup for the top and a 1.5 for the bottom, what do I have to do, buy 2 freakin headsets???wyatt79m said:I think the whole thing is dumb, and looks terrible. I really hope it just goes away.
The idea is that the majority of the force (at least in regards to stiffness and strength) is going to be at the lower race, and running larger ball bearings and larger diameter steer tube at that juncture reduces weight and increases strength. Whether that will be noticeable to the average rider may be questionable, especially since these forks are typically run in aggressive/freeride applications, where many of the 1.125 steer tubes are 1/4" in tube thickness at the base of the steerer anyway, and most of the afforementioned aren't too concerned about saving a few grams of weight.dan0 said:the tapered head tube allows more room to attach the top and down tubes so the frame will be stiffer, I really don't think the fork being tapered adds much if anything as far as stiffness, it only makes contact at the upper and lower bearings, so in my opinion an adapter and a 1 1/8 fork will be just as good for all intents and purposes
you only save weight over a full 1.5", you gain weight over a traditional 1 1/8"Jim311 said:The idea is that the majority of the force (at least in regards to stiffness and strength) is going to be at the lower race, and running larger ball bearings and larger diameter steer tube at that juncture reduces weight and increases strength. Whether that will be noticeable to the average rider may be questionable, especially since these forks are typically run in aggressive/freeride applications, where many of the 1.125 steer tubes are 1/4" in tube thickness at the base of the steerer anyway, and most of the afforementioned aren't too concerned about saving a few grams of weight.
Right, but it's a compromise of strength/weight characteristics that makes it desirable. But when you think about it, these tapered forks are being run on bikes where an extra 50 grams isn't going to make a damn bit of difference. I think I'd rather go full 1.5 steer, as the options for tapered headsets, and tapered forks, is much smaller than 1.125.dan0 said:you only save weight over a full 1.5", you gain weight over a traditional 1 1/8"
for now. That is always true of every new technology or standardJim311 said:the options for tapered headsets, and tapered forks, is much smaller than 1.125.
hmmm, bigger tube and less weight = thinner tube . dont see how you can have it both ways ( stronger/ heavier lighter /weaker) regardless , I think the difference between a tapered fork tube and a regular fork tube with adapter is not mucheric1115 said:Trek claims that going to a tapered head tube on their Fuel EX gained them 30% more stiffness in the frame, regardless of fork, and then another 10% with a tapered steerer tube fork. IIRC, that was only in reference to front-rear stiffness (so deflection under hard braking, etc.) I don't have their testing protocol and I can't vouch for how accurate their claims are, but they also claim that the bigger interface lets them use less material so there's not a significant weight penalty. You also get to use the myriad options of 1 1/8 stems instead of the handful of 1.5 stems.
The tube is larger but you can get away with running thinner walls.dan0 said:hmmm, bigger tube and less weight = thinner tube . dont see how you can have it both ways ( stronger/ heavier lighter /weaker) regardless , I think the difference between a tapered fork tube and a regular fork tube with adapter is not much
You can have it both ways, lighter and stiffer. If you don't believe me, come back and discuss it after you've taken a first-year engineering course (sorry, but it's very obvious that you have not). If you draw very simple free-body and shear and moment diagrams, you'll see that the bending moment applied to the fork is highest at the lower head bearing. Adding bending stiffness to that area is beneficial, adding it elsewhere is wasted material.dan0 said:hmmm, bigger tube and less weight = thinner tube . dont see how you can have it both ways ( stronger/ heavier lighter /weaker) regardless , I think the difference between a tapered fork tube and a regular fork tube with adapter is not much
Um...why don't ya read the answers given again...thoroughlyRicko said:Yeah, I agree...stupid! It sounds like I need a 1 1/8 cup for the top and a 1.5 for the bottom, what do I have to do, buy 2 freakin headsets???
emtnate said:King also makes a reducer cup if you don't want a tapered fork. It's part of the devolution line, if you're in luck, they'll sell just the bottom cup.
http://www.competitivecyclist.com/mo...548.462.1.html
crisillo said:correct, if you plan on running a 1 1/8" fork you will need a reducer cup in the bottom.
Or; I guess if you really want to you can go buy two headsetsChris King said:Already have a Chris King headset?
Because Chris King headsets share the same cups, a conversion kit is available to transform your current King headset into a Devolution™. We even offer kits to convert a Devolution™ to a NoThreadSet™, a 2Nut™, or a GripNut™.
