i've caught onto the uselessness of the the large chainring (44T) on my ride...i've got a standard 3X9 (44,32,22 and 11X34)...it's cheaper and quicker for me to deal just with the front rings and keep the 9 in back...so when folks talk about running 2 chainrings up front...the usually discard the outer ring on the standard 3 ring crank and just keep the 22 and 32 rings in thier original positions (inner and middle)...but some may use 2 rings that are different from 22 and 32 and run them in the same positions that the 22 and 32 were in?...some guys run a single ring up front, they put this ring in the middle position on the crank?...the middle ring generally gives the straightest chainline?...
if one runs a single ring up front...then they prolly need a chainguide to make sure the chain doesn't come off...could keeping the front derrailler, although superfluos, serve as a chainguide?
i often just stay in the middle ring for much of my XC work...maybe running a single up front, one can dial in thier shifting precisely and have almost flawless shifting but only 9 gears...i would take that in a heartbeat...if the front chainring isn't working...finding a different size is no problem
what don't i have right? thanks
