1 - 7 of 7 Posts
so heres my spiel...I have a raliegh m40dx ...and gary fisher marlin....i want to take suspension from the raleigh and put it on the marlin, alas the marlin has pull brakes, how do i know if the rear of the bike can support the disc brake....is this feasible? reason i am doing this is because the raleigh is a large, and the marlin would be much more fitting since its more my size, so it be nice if i could have disc brakes w/ good suspension....so yay or nay?
If that's what works for you yeah. Really your front brake is the one that you need more power with, that's where your stopping force is. That's why many people run a larger front disk than rear.
By suspension I assume you mean the fork. The fork on the Marlin is superior to the Raleigh, and it probably has disc mounts. So you could swap the brakes without swapping the forks.
Most modern quality frames have disc mounts, so you can probably put discs on the rear. Look at how the caliper is mounted on the Raleigh and see if the Fisher will accommodate it. If you can't tell by looking you probably shouldn't be screwing with the brakes, you might want to bring the bikes to a shop and have them take care of it.
1 - 7 of 7 Posts
