1 - 6 of 6 Posts
Warning: This was a Mickey Mouse project from the get-go. No precision tools or methods were used...just a hand drill, a file, and some J-B Weld! :skep: :skep: :skep:
I love everything about my new XT 776 wheelset except that the morons at Shimano left no option to have a bolt on rear hub (oh...and the Star Trek stickers on the rim are wearing thin on asthetic appeal). Had some time and this is what I came up with.
***Do not attempt this at home unless, like me, you have too much time on your hands and don't mind paying for a new axle and such if this doesn't work.***
The new XT hubs have a larger aluminum axle with a cone and steel lock-nut/end-cap on each end. The drive side cone and end/cap are thread-locked on. Took off the brake side end cap and the internal diameter of the axle appears to be approximately 10mm (don't have a caliper) and the #35 10X1X174 Wheels Manufacturing QR (hollow) axle I had laying around slid right inside! :thumbsup: That is until it met the reduced diameter portion under the freehub body. :madman: I assume the bore is smaller to provide more material to support the cassette.
Here's what I did. Using successively larger drill bits I drilled out the drive side of the axle to match the brake side. I ground off the QR posts on the steel end-caps and drilled them out also (now have to use vise grips to adjust the cone). Mixed up the J-B Weld and installed the Wheels Manufacturing axle inside the XT axle with a good dose of the sticky stuff along the way. I had predetermined how much axle needed to stick out on the drive side as I did not have the brake side end-cap on (didn't want it welded on too :D ). That's it. Time will tell if this will hold up. I'm not holding my breath but you never know. From my experience with J-B Weld, if I got good coverage inside the XT axle it's probably good to go.
This did add a bit of weight, I'm sure, but I did not get numbers. The axle and nuts aren't too heavy and I lost a QR. Honestly, I wasn't too concerned.
Note to self: Next time, don't use the fast set version...5 minutes goes pretty fast to install and clean up before the epoxy sets up!
Curious why JB weld?
If you didnt JB weld the axle in place, wouldn't this be the same as a thru axle 10mm hub, which IMO would be better? Also if you didnt use the heavy as poop WM axle, you could buy a much lighter Hadley 10mm thru axle or even a DT Swiss RWS and use without the JB weld. Just thinking.
10mm axle conversion
I remember Shimano's Hone group set which had the rear hub with a 10mm axle way back then.
Hoping your weld lasts ....
Premium Member
Exactly. There was another post where they just drilled out the end caps and used a through bolt skewer/axle.
1 - 6 of 6 Posts
