1 - 8 of 8 Posts
*R*O*W*Y*C*O*
Along with the new update to the Lupine Betty it looks like the Wilma got another make-over.
New front bezel ring, pcs switch mounted on the light body and 17W @ 920 Lumens now...?
LINK
But this is only the first half of the good (albeit quite old) news, if you know a little German you must also be aware of this:
"Es kommt noch eine ganz neue Einsteiger Lupine, ganz anderes Leuchtmittel ( natürlich auch LED ) , um die 700 Lumen und um die 300 Euro. Und von der weiss auch Veloplus noch nichts."
Even if your German is not that good the two numbers are kinda obvious :) Autumn's gonna look like interesting again...Can't wait...
*R*O*W*Y*C*O*
Discussion Starter · #3 ·
okay, as I read it...
A new 700 Lumen light from Lupine for around € 300.
Now that will be interesting.
Release date for the New Wilma is September 2008.
I like the switches just the way they are.:) It also seems like they take away some of the heatsink area by putting the switch there. I wonder if it will not dissipate heat as well as the older style Wilmas b/c of this.
*R*O*W*Y*C*O*
Discussion Starter · #6 ·
I do as well, that was one of the features I really liked about the Betty 6 and Wilma 6 when I bought them.
I wonder if the PCS will be affected by the heat generated.
Maybe this is just another option for the Wilma, with or without remote PCS switch.
Bodhisattva
That's a valid point. But if nothing else, Lupine is meticulous and thoughtful in their design so I'm sure they've taken the heatsink issue into consideration.
1 - 8 of 8 Posts
