1 - 4 of 4 Posts
Hello,
I've ordered a set of No Tubes ZTR Race wheels for use on my '06 Scott Scale 20. I've got the stock Shimano XT/XTR drivetrain on there and I'm wondering if all the parts will drop right in. I have the tools for removing the cassette and a new pair of rotors for the ZTRs (the stock wheels used the Centerlock rotors). AFAIK, this should be a fairly straightforward swap, yes? Anything I should be aware of when swapping a wheelset?
Thank you,
- jason
himom!
The new wheelset will probably need to be adjusted after a few rides as it "settles in". Otherwise, no worries. Just clean you cassette and chain when you remove them. It's a lot easier to do that when they're separated from the bike.
Discussion Starter · #4 ·
Thanks for the replies. I got the wheelset and have everything installed. Just had to adjust the brakes a little bit and they work very well. As far as adjusting the wheels goes, does that involve tightening the nipples? If so, how should I go about doing so?
Thank you.
1 - 4 of 4 Posts
