You can't look at his bike but only a website? How do you know if anything might have been swapped out or upgraded? Checked with what specs? Lever or caliper?EEB said:I checked on the Gary Fisher site. According to that his bike right now has Avid SD3 linear pull brakes. So what would you suggest for new V brakes, cables etc?
His bike is at his apartment right now so I can't actually look at it. He plans on bringing it down in about two weeks so we can start working on it. I have a room in the basement with a work bench etc. I know his bike doesn't have any upgrades. He bought it brand new in 2006 and hasn't done one thing to it.Bikinfoolferlife said:You can't look at his bike but only a website? How do you know if anything might have been swapped out or upgraded? Checked with what specs? Lever or caliper?
If the lever doesn't have the leverage adjust (aka Speed Dial adjustment), then look to new levers more than calipers. Do you know what a lever vs caliper in brakes are?
That's nice, but doesn't mean the gear is exactly as you might expect. Changes are made by manufacturers or retailers (or even in between) to spec, too...they're not always recorded. GF's site for the 2006 Marlin "brakeset" does indicate Avid SD-3 but isn't really specific about levers vs calipers. Bikepedia has the 2006 model with SD-3 calipers but Tektro RS360A levers. Best for someone to look at the bike and specify rather than assume a particular spec based on model/year.EEB said:His bike is at his apartment right now so I can't actually look at it. He plans on bringing it down in about two weeks so we can start working on it. I have a room in the basement with a work bench etc. I know his bike doesn't have any upgrades. He bought it brand new in 2006 and hasn't done one thing to it.
I know the difference between a lever vs caliper are. I don't know as much as some on this site but I'm not that dumb...![]()
Since you have SD-3 brakes and Tektro levers...you might consider new Avid FR-5 or SD-7 levers, new top notch brake cables and housing, and top quality brake pads. The SD-3 brake arms are actually not bad.EEB said:A friend of mine has a 2006 Gary Fisher Marlin. He wants to put new V brakes on it when we change the brake cables etc.. What are some good V brakes without spending to much?
