That would be sweet!Check this out, just grabbed from Turner’s IG stories...
Rear axle spacing in the last pic confirms this hypothesis.Look at the rear stays - it's a fat bike.
You're right. I didn't notice that.Look at the rear stays - it's a fat bike.
Clearance near t47 BB omits this hypothesis. It is a super boost 29+. Btw what do Nos (Holley) and Turner have in common, perhaps same financier? Just a speculation, but Nos is a registered trademark so one can not just use it freelyRear axle spacing in the last pic confirms this hypothesis.
Renowned ti builders like MootsExcuse my ignorance but who are NOS?
Well the numbers are very similar to my Waltworks Ultimate Warrior so I can promise you that this thing should rip!Frame is imported. double butted top tube, down tube and head tube. Chainstays are single butted and tapered. 29x2.5", Boost spacing. BB is T47, 73mm wide. Flat mount 160, as started by Noble Bikes. Geo with a 130 fork: 74SA, 66.8HTA, 415 CS, 12mm drops, 620ETT on medium, the head tube is a very common 44x56 . This is not supposed to be an 'enduro HT', there are plenty of those to choose from. This is my take on 'PB Mikes' down country XC bike. I live in suburban hell, with nothing but tiny pockets of dirt between large expanses of pavement. A gravel bike is my go to for most of my solo rides. But occasionally I will find myself way outside my comfort zone on a gravel bike, and although the Cyclosys makes it thru with brakes smoking and careful line choices, a down country style hardtail would allow for greater speed and more fun. Then back on pavement, lock the fork and toil on. I did not give much thought to 27.5 on this frame and I'll tell ya why. The primary advantage to using a 27.5 on the rear is to shorten the CS. Well at 415, this is plenty freakin short and I have the advantage of a 29" for rolling over ****. Going to a 275 the only way to get the roll over of a 29r back is to use a 275x2.8 or 3.0, and in a decent casing thickness, these are freakin HEAVY. I want a step between a full suspension mountain bike like my Czar or Flux and a gravel bike, not replace my Burner or Sultan. My plan for this is a fast feeling bike. Fast locked out on pavement and smooth dirt roads, and fast 'feeling' on the descents. I am well aware that full suspension bike can be faster on rough descents, but with a sub 12" BB and kinda slack HA this will give a lot of confidence. As for using the Holley automotive and CocaCola owned energy drink Nos art, I thought it looked cool and am pretty sure a proto frame isn't going to get me called into court.
Interesting. Thanks for the detailed response.Frame is imported. double butted top tube, down tube and head tube. Chainstays are single butted and tapered. 29x2.5", Boost spacing. BB is T47, 73mm wide. Flat mount 160, as started by Noble Bikes. Geo with a 130 fork: 74SA, 66.8HTA, 415 CS, 12mm drops, 620ETT on medium, the head tube is a very common 44x56 .
Nvmd. Responded before seeing the many replies that followed this one.Clearance near t47 BB omits this hypothesis. It is a super boost 29+. Btw what do Nos (Holley) and Turner have in common, perhaps same financier? Just a speculation, but Nos is a registered trademark so one can not just use it freely
