1 - 20 of 29 Posts
I've got this up in the custom forum, but nobody reads there.
About 30 months ago I took possession of my first TrueFabrication frame. As it happened it was the first production frame (I guess I was friend # 11).
This sleek fast SS beauty was just what the Dr. ordered after my Niner RIP9 started to disappoint me as an all around bike.
Well the disappointment from the RIP was not over once I was able to reclassify it as just a play bike. It continued to be a bland bike until one final ride, around 18 months ago, when the frame just gave up and cracked. RIP the RIP.
Niner promptly replaced the frame which I had sold before it even showed up. So with a pile of cash and an interest in something fancy I started looking around. The shop I work at, Hammerhead Bikes, had decently large demo fleet and I took an immediate liking to our 4"/5" El Rey. I moved a bunch of my RIP9 parts over till the shop had a full 5" all mountain El Rey. I rode the crap out of it and pimped it to all who would listen. Around that time Cody, the shop owner and part owner of True offered me a solution. He and TF would build me my own TrueFab/Ventana. Only we would make it better.
So Cody and I spent a lot of time talking, measuring, and calculating. Eventually we settled on a CAD plan and Clark/Cole/Mo went to work building. It took a lot of trial and error to get things put together, but here is the near final product:
So the final setup is as follows:
2010 True Fabrication 5" FS frame.
Fox 36 Float 5" cut fork
DHX Air 5.0
Hammerschmidt
XO Shifters
XO Rear D
Hope Tech X2 183mm brakes (F&R)
Industry Nine Enduro 29r wheels
I don't have any final photos, but I will have some tomorrow to post.
On my local board I got a lot of people asking why a TF and not a Ventana and why in steel. My response:
Steel provided me the opportunity to have the bike built by local builders who I know and trust. It let me spec the geometry just the way I wanted it. For this frame we moved the lower pivot point forward, giving the frame a shorter effective chainstay than a stock Ventana. Because Ventana uses a prefab Yoke, rather than individually welding the BB area this was not an option from them. We were also able to adjust the BB to sit a touch lower, making up for the uncomfortably high BB that results from using a 5" rocker set. We also played with the HT angle and ETT, but those are both available from the Ventana custom program.
I like the ride of steel. I know this is a bastardization, with the rear Al, but the front end still has the feel of steel vs the vibration and feedback characteristics of Al.
We spec'd the frame with a HUGE (by steel standards) down tube and a sleeved seat tube since these are the areas that fail most often on the larger travel 29'rs.
In the end the weight of the frame was not that much heavier than the Ventana Al version, at least not considering all the extra bulk built into this frame to prevent future breakage. The normal weight of an El Rey is 6.35lbs. The TrueTanna came in at 6.9 lbs. Fine with me. And that includes the ISCG mount.
I've got two short rides in, one a shake down and the other a more technical ride for suspension tuning. The tuning is going to take a little time, but I am confident in saying this bike climbs like a mountain goat on speed. It handles faster and more fluidly than I can ride at this point. I'm going to have to get better.
More photos tomorrow.
Student of the Bike
Matt,
I'm glad you like your bike. Its been a fun project and we look fwd to doing more. I think it turned out very well. Here are some photos that were taken today. Better pictures to come once the weather gets better.
In FTF We Trust
Did they tweak the bb/seat tube pivot location? It looks like it lines up pretty darn close to the chainline of the Hammerschmidt. That should pedal great without much if any pedal feedback. I love the sleeved seat tube and the elegant brazed curved top tube/seat tube brace. Very impressive bike!
Discussion Starter · #13 · (Edited)
The lower pivot point was moved from the standard Ventana location, mostly to create a slightly shorter effective chainstay. The resulting chain relationship was to my knowledge not intentional, though clearly beneficial.
Austin kills Ventanas. The sharp edges on our 1-3ft ledges seem to put undue stress on the seat-tube and we crack them more than most places in the US. So the sleeved seat tube and the location of the lower shock mount were important for reducing the likelyhood that I would see a failure in the same area.
Lastly the curved brace was all me. I wanted something that tied this frame into the TF family. All of their bikes have beautiful hand bent stays with perfectly flowing braces and arches. This frame was going to be fairly linear, so I asked for a curved brace. The piece used is actually just a leftover seat stay arch brace.
The bike was built to be a very utilitarian bike. It's spec'ed with the best parts I could imagine, with the sole purpose of being a riders bike. It is not a light bike, but by comparison it is not so bad. 34lbs as pictured. It could easily be a lb lighter if I wanted to throw some carbon on there, a lighter fork, or lighter tires, I just don't care. It really flys up hills as is. The 22t HS and the 34t cassette should be able to handle anything I could care to ride my heavy bike up.
Very cool project. Have you posted a final geometry spec? BB height, CS lenght, HA, ST Angle, etc? I'm interested in how you've modified the Float 36. Sounds like you shortened the travel to 5" (how do you do that?) and ground out the arch for more clearance.
Looks like True Fab would be a good place to start for a 650b TruTana. Did you consider that?
Looks really sweet and the frame weight is comparable to others of it's kind out there, if not a tad lighter. You said you rode around the El Rey in 5" form for a while, how does this frame compare to that as far as stiffness is concerned?
Discussion Starter · #20 ·
I'm a 29'r guy, not interested in messing around the the 650 stuff. Though if you did go the 650 route you could probably run an uncut fork.
Fork travel is limited to 5", fairly easy to do. The AC measure was not changed. The mod is fairly common, and there are topics on here at MTBR.
Geo data shortly.
1 - 20 of 29 Posts
