My new FS bike came with Maxxis Lust's. What should I carry in case of a flat ? I'm used to always having a pump and spare tube on hand, but what do I need to carry for my tubeless?
Several ways to go:onbelaydave said:My new FS bike came with Maxxis Lust's. What should I carry in case of a flat ? I'm used to always having a pump and spare tube on hand, but what do I need to carry for my tubeless?
I had a flat 1/4 of a mile into my first ride w/ Tubeless; never really warmed up to them and finally sold them. My friends w/ Tubeless tires get flats at about half the rate I do; perhaps 3-4 times a year?dulyebr said:haven't had a single flat in 3 years of running UST tires. I don't bring anything anymore.
Are these flat from sidewall tears? If they're punctures, they must be really huge for the UST tire to go flat right away. I have lots of small punctures, but it's not a big deal, I just top-off before I ride each time - no sweat.MightySchmoePong said:I had a flat 1/4 of a mile into my first ride w/ Tubeless; never really warmed up to them and finally sold them. My friends w/ Tubeless tires get flats at about half the rate I do; perhaps 3-4 times a year?
Dave
So I bring a tube and a pump. That didn't prevent me from walking home a couple occasions, having flatted midway into my ride. Not a 1/4 mile into it. Not a 1/2 mile from the end, no. More like a 7-mile walk. Sweet. Once the tube had a hole in it, the other time I couldn't get a hang of the CO2 device... That's what happens when you're dumb and ride too muchdulyebr said:haven't had a single flat in 3 years of running UST tires. I don't bring anything anymore.
We ride in a _ton_ of really nasty rocks. I'd image a tubeless w/ slime/stans would do really well w/ goatheads. When I was in NM I always had to have slimed tubes.dulyebr said:Are these flat from sidewall tears? If they're punctures, they must be really huge for the UST tire to go flat right away. I have lots of small punctures, but it's not a big deal, I just top-off before I ride each time - no sweat.
You can add a scoop of Stans to the UST tires if you have a lot of piecrcing plants on your trails e.g. goatheads.
If the flats are from sidewall tears, look into getting a UST tire with thicker sidewalls. Some of the lite version of UST tires are light due to thinner side walls. The Maxxis LUST version and the Continental Protection series are supposed to be very tough.
Overall UST is really great if you don't mind a little extra weight and expense.
I know no one that carries acetone on a ride.theProfessor said:Carry a pump and;
REPAIRING UST TYRES
A. Repairing punctures (smaller than 4mm cuts)
1. Don t remove the tyre.
2. Dry the damaged area.
3. Clean it with acetone.
4. Pinch the tyre, so that the hole will open.
5. Glue the hole with cyanoacrylate glue (Loctite 4850).
6. Let it dry for approx. 3 minutes (keep the hole closed).
7. Inflate the tyre to the recommended pressure.
B. Repairing punctures (larger than 4mm cuts)
1. Remove the tyre.
4. Pinch the tyre so that the hole will open.
7. Remove the tyre from the rim.
8. Turn the tyre inside out.
9. Find the hole and spread a thin layer of glue on it (Loctite 4850).
10. Let the glue dry for 15 seconds.
11. Put the rubber patch to the glued area and press it for 1 minute.
12. Reinstall the tyre.
13. Inflate the tyre to the recommended pressure.
I do exactly the same here,trust and hope.I havent head a flat on any of my bikes in near a half a decade.I ride near 100 miles a week,on all sorts of terrain.theProfessor said:For what its worth, I don't carry anyting, use no sealer, and trust the tires.. for now..
