1 - 12 of 12 Posts
Picture Unrelated
I suggest a new bike unless you're very familiar with how bikes should operate or are able to take a used bike to a shop and have it looked at before you buy. That being said, a used bike is a good way to save a lot of money, just be careful of what you buy.
~Disc~Golf~
tbreed725 said:
i guess i was kinda mis leading as thta would be what it was used for the majoroty of the time occasionally going into the woods mostly though thru the park or on trails
What year is it?
The older ones might have better componentry...
~Disc~Golf~
here's the bike specs
http://www.bikepedia.com/QuickBike/BikeSpecs.aspx?ItemID=37284&Type=bike
Bicycle Type Comfort/commuter
Sugg Retail $199.99
Weight Unspecified
Sizes 14", 16", 18", 20", womens 16"
Colors Unspecified
Frame & Fork
Frame Construction TIG-welded
Frame Tubing Material Chromoly seat tube/hi-tensile steel
Fork Brand & Model Unspecified
Fork Material Hi-tensile steel, unicrown crown
Rear Shock Not applicable
Components
Component Group Hybrid Mix
Brakeset Aluminum linear-pull brakes, aluminum linear-pull levers
Shift Levers SRAM Verio
Front Derailleur Shimano Tourney TY-32
Rear Derailleur Shimano C050
Crankset Shimano Tourney TY-33, 28/38/48 teeth
Pedals Nylon
Bottom Bracket Unspecified
BB Shell Width Unspecified
Rear Cogs 7-speed, 14 - 34 teeth
Chain KMC Z-51, 1/2 x 3/32"
Seatpost Aluminum, suspension
Saddle Selle Royale Freedom Gel
Handlebar Steel, 30mm rise
Handlebar Extensions Not included
Handlebar Stem Aluminum, adjustable
Headset 1 1/8" steel
Wheels
Hubs Aluminum, Q/R
Rims Alex Z1000, 36-hole
Tires 26 x 1.95" Hutchinson Acrobat
Spoke Brand Unspecified
Spoke Nipples Unspecified
Like I was sayin earlier, it's not for MTB, but if ya wanna cruise smooth trails, it'll be fine - offer the dood $50
1 - 12 of 12 Posts
