1 - 3 of 3 Posts
Addicted to Dirt
I received my new Bianchi SASS yesterday (pics to come) :thumbsup: I could not take it out on the trails because the seatpost is too short and I didn't want to blow my knees on the first ride, but it felt great on the few laps that I did around my neighborhood :D
Questions:
- What tool do you guys normally take on the trail to remove the rear wheel (adjustable wrench, box wrench...)
- The geometry seems very agressive (compared to my stumpjumper FSR 120) which makes it harder to lift the front wheel, what's the best solution for that (longer fork, shorter stem...)
- When I took it down some curbs it makes a lot of clunking noises on landing. Is that a product of the pos headset or is this normal for rigid SS?
15mm stubby combo wrench from Craftsman will handle your axle nuts fine with out lugging a full size wrench.
Your bike should not be clunking. Sounds most likely to be a loose headset. You will need to loosen the bolt(s) on the stem to adjust the headset.
Craig
34N 118W
ingluis said:
Questions:
the Surly Jethro Tool will do ya. And it's pretty handy with a bottle cap too.
shorter stem or one with some (more) rise. Slide seat back on rails if fit allows.
not normal.
1 - 3 of 3 Posts
