1 - 11 of 11 Posts
· Registered
I just bought a used GT Timberline. I believe i need a new crankset. Im new to Mountain Biking and am a little lost when it comes to components. The bolt that holds the left crank arm on keeps backing out. Any suggestions. I have tried lock tighting the bolt in and it didnt work. Will all cranksets work and what do i need to look out for while shopping around for them?
· I'm Riding It
Hmm.. loctite didn't work?
I don't know what to say, there might be some bigger issues if loctite isn't working.
I suggest bringing your bike to your LBS and it might end up being a smaller fix (than buying a new crank anyways) and if not, they will point you in the right direction as far as what kind of cranks you should be looking for.
Hope that helps.
· Picture Unrelated
Unfortunately, it sounds like it might be damaged. The LBS should be able to tell you for sure, but I would think it's time for a new crank.
· Registered
Discussion Starter · #9 ·
Just took the bike to the LBS. Found out that the crank was the least of my worries. Apparently my front shock was off of a walmart bike without the stickers and it was basically blown out i guess. In order to replace the fork, i had to replace the stem, headset and handlebars. This is on top of the beat up crankset. Its definately become a money pit and i havent had the chance to put it on a trail yet.
1 - 11 of 11 Posts
