1 - 3 of 3 Posts
stalker
I just bought a '10 Talas 32 150 and my question is, how can I check to see if it came with the right amount of oil and can I do it without having to replace the oil incase it's full?
Thanks for any help.
you'll have to disassemble the fork to check the oil levels as the only way to really know is to dump and measure. i don't believe fox is publishing the damper oil height measurement, only volume.
the lowers use so little oil for lubrication that reusing isn't really practical once you pull the lowers (i suppose you could pull the lowers while horizontal and measure the volume after you dump it but it would be much easier and faster to just replace it). the damper oil can be reused if you're careful - pulling the fork off the bike first will help a lot.
service.foxracingshox.com will be helpful
1 - 3 of 3 Posts
