1 - 20 of 29 Posts
New Superfly is here, XL at 22.0 lbs
Got most of my modifications done. Might change out the seat for something lighter. I have some Racing Ralphs for races later in the season that should drop some weight. Could go with egg beaters but our team is sponsored by Shimano. I like my 2x9 crank setup although it could be lighter.
Check the previous post for the changes: http://forums.mtbr.com/showthread.php?t=381135
2008 Gary Fisher Superfly
Size XL
Weight as pictured: 22.0 lbs
Fork: Fox F80 RLC G2 Geometry
Headset: Cane Creek ZS-6
Crank: Bontrager Race X-Lite Carbon with Custom Spider 26/38 rings. 175mm
Bottom Bracket: SRAM Blackbox Ceramic
Pedals: Shimano XTR M-970
Front Derailleur: SRAM Force with Custom Pulley wheel
Rear Derailleur: Shimano XTR M-972 Shadow Medium Cage with KCNC alloy pulleys with ceramic bearings
Shifters: Shimano XTR M-970 Triggers
Brakes: Avid Juicy Ulitmates
Cassette: Shimano XTR 11-34
Chain: Shimano XTR 9 speed
Handlebar: Bontrager XXX Lite
Stem: Bontrager Race X-Lite 105 mm
Grips: Fizik Bar Tape
Saddle: Bontrager Race Lite
Seatpost: KCNC Ti Pro Light
Rims: Stans ZTR 355 29er
Hubs: DT 240s with Ceramic Bearings
Spokes: DT Revolution Black
Nipples: DT Alloy Red
Rotors: Stans Aluminum 160mm
Skewers: Edge Titanium
Tires: Kenda Small Block 8 rear, IRC Notos 2.1 Front
Cables: Nokon Red
Ti and Al bolts throughout
bikerb,
i also have a set of stans 355's on my kona kula ss. i was thinking of swapping them w/the botragers my superfly came with. i haven't gone thru the weight exercise yet to see the difference, but i suspect there is a slight savings with the 355's. but do you think the 355's are as stiff laterally as the bontragers?
obvioulsly you felt there was upside in going with stans 355's, just want someone to convince me to make the swap.
No longer 26
Looks great but Avid brakes and a Sram der on a Shimano sponsored bike? WUWT?
Just kidding, nice weight and set up!
G
Old Fart at Play
You really need to get that fork painted black, with red details of course. ;)
RockStarRacing said:
nice cranks, who did the custom spider, and id be interested to see the custom wheel for the sram front mech.
Who did the custom Spider? I'd like to know that also as I used to run a 2x9 setup and would consider going back.
Just got my superfly. Pretty much stock, cept' WTB Rocket V ti saddle, and xxxlite riser, crank bros pedals. With tubeless its just under 23 lbs
Discussion Starter · #10 ·
William D said:
bikerb,
It should be more than a slight savings. The I saved around a three quarters of a pound. Given that, they are definitely not as stiff, but I only weigh 150 lbs so its not as big of a deal for me. It also depends on what kind of spokes you are running on it as well.
Discussion Starter · #11 ·
My dad and I made the custom spider ourselves. It took a lot of time on the drill press. We started with this: http://cgi.ebay.com/Azonic-454-crank-spider-5-X-110mm-Bronze_W0QQitemZ320094186395QQihZ011QQcategoryZ56193QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem then machined the interface for the bontrager crank.
For the pulley wheel we took a front derailleur clamp and drilled a hole in in and put a nylon screen door wheel on it. It allowed me to use the Sram Force bottom pull front derailleur.
No longer 26
SJ9,
Just get some blackspire 26/38 rings for your crank, no need for a customer spider unless there is a specific requirement the blackspire rings don't cover?
G
Discussion Starter · #13 ·
G-Live said:
SJ9,
G
It was more than just the chain rings. The new spider gave a better chain line than using the stock bontrager setup with a 2x9. The 110x74mm BCD is ideal for the rings you would want to use on a 29er and they are easy to come by. 110mm 5 bolt is just a standard road compact setup so they are pretty easy to find, as well as cheaper than the blackspire rings.
Discussion Starter · #14 ·
20.100 FR said:
Beautiful setup.
Did you offset the rings, so that the little is in the middle position, and the medium in the big ring position ?
Not really. They way they are without any offset is the ideal chain line. I can use every gear without feeling like I'm cross chained at all. They are probably half-way between the granny and middle for the small ring, and the big ring is probably half-way in between the middle and big ring position on a normal crank.
more on the crank 2X9
bikerb (also known as my son) and I did a lot of thinking on this. I haven't posted my bike, but it's a Large Superfly that weighs 21.3. My crank is a Bonty road triple with the same custom spider. There was no way to run a standard mtb spider on it without hitting the chainstays with the chainrings. The custom spider allowed that for me.
My Q-Factor is as absolutely narrow as possible while allowing me the widest choice of chainrings. The 74mm inner allows me to run 24,26,28, or 30. the 110mm outer allows 34,36,38,39,40,42 all easily obtainable. Optimal chainline to boot.
On a final note, I have an artificial hip so my Q-Factor is very important to me. This setup did the ticket for us to get optimal Q and optimal gearing. As far as I know, I have a narrower Q than JHK, and I know Jeremy is a stickler on Q!
Nice job father and son team. :)
My medium Superfly is still stock, except I changed the saddle (Selle Italia SLR), put ultralight tubes and eggbeater 2Ti pedals. It is still a bit over 23 lbs, but that is OK for me.
No longer 26
The Blackspires (in 24/36) work well for me on a standard GXP crank. Using the middle ring 80% of the time except for climbing. I have not had any problem with chainline at all. I did have a little rubbing on the big ring with an isis crankset when in the granny. Changed it out to an outboard bearing crank and works great.
Your spider adjustment probably makes it even a bit better. I wonder how easy it would be to make 26/28/36/38/40 tooth rings with a 2 or 3 mm offset to accomplish similar results for standard 4 bolt cranks?
G
Discussion Starter · #19 ·
SingingSingleTracker said:
Oooooolaaaalaaaaa that's a nice bike. How much total $$$$ were involved.
Don't really want to think about it...
But I'm a sponsored racer so that helps out a lot.
OK yeah, this was running through my head also :???: You say you didn't run the Eggs because you're Shimano sponsored and yet are running products by both SRAM and AVID that Shimano also has offerings in :???: Would have thought you'd maybe go with the new XTR brakes, cranks and wheels :skep: :???:
BTW super nice and super light bike.
G
1 - 20 of 29 Posts
