ETA June 1st!HTail said:Have any of you seen the ad for the new SRAM XO trigger shifter and XO Blackbox technology rear derailleur? Is this available now?
A slight correction to Angel Crusher's post - with a Shimano rear you need to run the SRAM 2:1 shifters. The easy way to tell is the 1:1 shifters are numbered, X.0, X.9, X.7, etc and the 2:1 (Shimano compatible) shifters are named, Rocket, Attack, etc. You can mix up the drivetrain beyond that to your hearts content.Angel Crusher said:You can mix and match componets to some extent. Obviously you can use a XT/XTR rear with SRAM 1:1 shifters, you can use a shimano cassette and/or chain. I run an X.9 drivetrain with X-Gen front, but I use an XT cassette. Everything works great and the shifting is far superior to the old XT/XTR setup I had before.
Forgive me for being confused, I was under the impression that all front derailleurs were 1:1... I had a mechanic tell me this too but I wouldn't be suprised if this was wrong.XSL_WiLL said:It'll work fine. Sram front derailleurs are still 2:1 actuation ratio. Rear derailleurs are 1:1. I'm using a SRAM cassette and PC 69 chain with Shimano Deore/XT derailleurs and Truvativ cranks.
That is unless it's Rapid Rise. Than Attack and Rocket shifters will work backwards. You'll only be able to downshift one cog at a time, just like XTR ;-)Mike B. said:A slight correction to Angel Crusher's post - with a Shimano rear you need to run the SRAM 2:1 shifters. The easy way to tell is the 1:1 shifters are numbered, X.0, X.9, X.7, etc and the 2:1 (Shimano compatible) shifters are named, Rocket, Attack, etc. You can mix up the drivetrain beyond that to your hearts content.
Prefer putting the horse before the cart. The cable controls the derailleur, not the other way around. It's 1:2 actuation (though, I've seen it used both ways).XSL_WiLL said:Nope, all front derailleurs, and Shimano derailleurs are 2:1. Only the SRAM X-Gen Rear derailleurs are 1:1.
