New slayer frame size
1048 Views 2 Replies 3 Participants Last post by  rockyuphill
Hi Every one , got my new slayer 18", problem is to get the right saddle height the post is
just above minimum insertion mark . My inseam is 32" do you think i would be better of with a 19 " frame. Thanks in advance .
1 - 3 of 3 Posts
You need 100mm of seatpost insertion, regardless of where the minimum insertion mark is on the post. A 400 or 425mm post may be the right solution.
It's all about top tube length, you can always fiddle with seatpost length, but you want to make sure the top tube length is correct.
1 - 3 of 3 Posts
