Just mounted two sets of the 2011 Schwalbe Racing Ralph Pacestar TR 2.25in tires. One set was mounted to Stan's Arch rims, and the other mounted to the new Specialized Roval Control SL wheels. Both sets of tires measured around the 50-51mm mark. One pair weighed in at 576, 579 grams, with the other weighing in at 552, 555 grams. The lighter set was mounted to the Control SL's.
The set mounted to the Arch's measured at 50mm spot on. The set mounted to the Control SL's measured in at 51mm. Both were measured at the casing. The crazy part is the internal width of the Arches is 2.5mm narrower than the internal on the Control SL's. I have the set on the Control SL rims pumped up to 45psi to stretch and will get measurements later.
Just wondering if anyone else has had a similar experience.
