I just installed this today, looks sharp and makes my Intense 6.6 feel much more stable in the rear.
The thing with a thru bolt is that there are different bolt options. For example the new Tracer 29 will come with removable dropouts. So does the Niner RIP. You can use a standard vertical type dropout or a Maxle which has a thread in the right hand dropout. The axle threads into it. If they gave you an axle with the hub it would be more expensive.RIfreeDE said:It really should come with the hub. What good is a hub with no fixing bolt?
Thanks for that. I'll give them a try.RIfreeDE said:Well with the 10mm hub I have there is only one option, so for the price of the hub it should come with. Regardless, I looked online everywhere and found it at ebikestop.com. Justin is ur man there. They are real good.
